What’s going on? Mix issues.
Old Oct 3, 2018 | 01:18 PM
JigJag's Avatar
Default What’s going on? Mix issues.
I recently replaced theree injectors. I had a misfire that was greatly improved by the replacement.
Before this swap I ran my mix at the clockwise extreme setting. This was better than any other setting, which caused worse running.
After the swap I am running my mix at the extreme counter-clockwise extreme. Any other setting causes increased missing.
I can state with fairly good confidence that I am missing on only one cylinder and not constantly, but steadily. Perhaps every other or 2 out of three.
When cold started, it runs much more smoothly. A miss on occasion but more on the order of 1 in 10. Still isolated to one cylinder. This worsens as the engine warms.
Obviously I need to resolve which cylinder. But I’m trying to understand what is going on here. I see that the mix affects the miss. So I assume it’s running near the edge of acceptable fuel air ratio.
My presumption before. The injector swap was that I had one injector not delivering sufficient fuel to fire, the O2 sensors saw the free oxygen in the unburnt charge and riches up the mix to fix it. Running my mix rich helped this cylinder and thus the correction was reduced or happened less frequently.
to be honest, I’m not sure which direction is lean vs rich. Experimental results and just based on improvement.
I plan to go through the injectors disabling one at a time to determine which is problematic this weekend.
Anyone have any input on this situation?
Old Oct 4, 2018 | 04:01 AM
warrjon's Avatar
I had a problem with 1 cylinder not firing on the A bank years ago, and to isolate which cylinder I pulled ALL the injector connectors off the B bank so the engine ran on the A only, you could hear the miss disconnect one injector at a time and listen to the engine, the idle will get worse until you disconnect the injector on the cylinder not firing.
Old Oct 4, 2018 | 06:59 PM
JigJag's Avatar
Thanks Warren, I do want to determine which one is still under-performing. Perhaps some debris in the screen. But all 12 are new.
I appreciate the method suggested. Sometimes it really is harder to pinpoint a miss on the V12. Pulling a whole bank out is a great idea. Did you start it on 6 too, or D/C the injectors once it was running?
I think I’m might pull the whole rail, connect up my test pump/regulator setup and signal generator. Run each one for 1000 cycles and do a volume check.
Old Oct 5, 2018 | 12:02 PM
JigJag's Avatar
Cranked my fuel pressure up to 42psi this morning. Really close to proper idle. Closer that I’ve ever gotten. Need to buy an O2 analyzer and see where it’s actually at. I know there is a method of using the O2 sensors output to do so, but I can’t recall where I saw the method written up. EDIT:found it.
Old Oct 7, 2018 | 05:10 PM
petemohr's Avatar
Originally Posted by JigJag
I know there is a method of using the O2 sensors output to do so, but I can’t recall where I saw the method written up. EDIT: found it.
Hey JigJag - Where did you find it? Can you post it?
BTW: I'm in Pittsboro, NC, near Raleigh. Are you anywhere nearby?
Old Oct 8, 2018 | 12:26 AM
warrjon's Avatar
Be a bit careful with an O2 analyser if 1 cylinder is not firing and ECU adds additional fuel to the others then the O2 might be close to spec.
I disconnected the whole B bank then started the engine, it'll start and run fine on one bank.
I would not use a siggen, at 12 volts the injectors will draw about 6 amps most siggens will not cope with this current draw and if it does not have over current protection you could damage it. Just use a push button switch and 6 volts
marcgr
Jan 16, 2014 10:29 AM
StumptownX
Dec 28, 2011 02:29 PM
Craig Schmidt
Oct 26, 2011 05:54 PM
veffremov
Audio/Visual Electronics
Oct 31, 2010 09:24 PM
maikal_0011
Jun 29, 2010 08:20 PM
