What did I just do ?
Old Apr 6, 2017 | 03:46 PM
baxtor's Avatar
Originally Posted by NJ2003XJ8
I am curious to know if anything in fact broke.
To set timing and valve clearances one has to turn engine forward to have all 'plays' and 'chain sags' in the same position they would be when engine is running. While turning engine back seem like something we never (or rarely) do, I have issue accepting that turning engine back few degrees will "likely" break something. I think it is actually "unlikely".
In my experience the jag v12 tensioner is generally trouble free in service. The issues with it cracking or breaking come when it is straightened for engine work or when released after the work.
There is not a lot of pressure on the tensioner on the slack side of the sprockets but backwards rotation will vastly increase the pressure on the tensioner as the chain pulls tight not to mention the mistiming that will cause between crank and cams.
Old Apr 6, 2017 | 04:17 PM
NJ2003XJ8's Avatar
Thank you, that explains.
I also understand that when engine always rotate in one direction all sliding parts develop 'fur' that does not like to be rubbed backwards. However, if I took 100 random XJS engines and turned them back let's say 5 degrees - how many would you expect would require repair after that?
Before reading this thread my guess would be "maybe 1".
Old Apr 6, 2017 | 04:31 PM
ronbros's Avatar
related to LUCK, hows your luck running?
Old Apr 6, 2017 | 05:25 PM
baxtor's Avatar
i think you would be pretty close to the mark.
The thing that would be the most annoying with such a breakage would be knowing that by turning that small amount backwards you are risking breaking something for no real gain. Any timing you set on any "driven" component after that backwards turning will be incorrect anyway.
Old Apr 6, 2017 | 07:53 PM
XJSGirl's Avatar
I really feel for you. I think we have all been there, thinking we are doing something good and wham, you realize you just screwed something up. Wisdom and knowledge can be hard earned, all my best getting your car back in good order!
Old Apr 8, 2017 | 03:45 AM
John1949's Avatar
I have from time to time turned engines back a couple of degrees with no harm .This a long shot but is there any chance that the crankshaft bolt " cracked " open , they are usually extremely tight but worth checking. If it where my engine I would turn it over a couple of times by hand even if it meant removing plugs to lower compression and listen as well as feel to determine if it is ok .It may also be worth checking all belt driven items and see if any of those have a broken or cracked mount causing the belt to squeal and then its a punt to decide wether or not to hit the key or check the timing chains .
