What Size Spark Plug Socket Wrench For AJ16 Engine?
Old Sep 3, 2018 | 06:10 AM
orangeblossom's Avatar
Default What Size Spark Plug Socket Wrench For AJ16 Engine?
Hi Guys
What Size Spark Plug Socket do I need to remove the Spark Plugs on a 4.0L AJ16 Engine?
Old Sep 3, 2018 | 06:54 AM
5/8 Long.
Old Sep 3, 2018 | 07:04 AM
Originally Posted by Grant Francis
5/8 Long.
Hi Grant
Cheers!
The only size I haven't got! but I'll get one
Another Forum said 16mm which I have got but it did feel a little bit loose, so I thought I'd better double check
Old Sep 3, 2018 | 07:38 AM
leo_denmark's Avatar
16mm will do. It’s 5,04/8 of an inch, ie within 1%
Old Sep 3, 2018 | 09:14 AM
Hi Leo
I used a 16mm on my V12 because at least you can see what is happening but on an AJ16 the Spark Plug is a long way down that hole and if it were to round off, for some reason
Then you might have to do some dismantling to try and get the Plug out
Old Sep 3, 2018 | 09:26 AM
Daim's Avatar
Originally Posted by orangeblossom
Hi Leo
Mate, the rest of the world, apart for UK and USA use metric tools on the AJ16. 16 mm is more than sufficient!
Just as a 'the more you know': the AJ16 is te second purely metric engine from Jaguar. The AJ6 being the first (at least to my knowledge). So even the spark plugs were chosen to be as metric as possible.
.04" is like nothing. You won't strip or snap the plugs if you just turn them properly. If needed back and forth until out. I doubt anyone has ever managed to snap plugs in the AJ16. The V12 is understandabe due to the angle but not the AJ16...
Old Sep 3, 2018 | 02:51 PM
Hi Daim
In that case I'll give it a try
Lagonia
Feb 12, 2022 11:18 PM
romroc
Aug 1, 2017 06:52 PM
Griff79
US Central
May 9, 2017 09:20 AM
Jagfrenchie
Mar 30, 2015 08:34 AM
1100me
Oct 27, 2014 03:55 AM
