What is this Wire for?
Old Sep 19, 2017 | 03:38 PM
orangeblossom's Avatar
Default What is this Wire for?
What is this White Wire with the Black Connector?
Old Sep 19, 2017 | 04:17 PM
warrjon's Avatar
That is the dreaded white wire.
On Marelli cars (early ones at least) pin 24 of the Marelli goes into the engine bay and connects to where the Lucas ignition amp used to be. Obviously Jaguar did not change the main harness through the car.
Old Sep 19, 2017 | 04:41 PM
Hi Warrjon
Cheers!
Obviously essential that it doesn't become disconnected.
Old Sep 19, 2017 | 07:29 PM
baxtor's Avatar
Originally Posted by orangeblossom
Hi Warrjon
Cheers!
About as important as oxygen is to you OB.
Old Sep 20, 2017 | 04:50 AM
warrjon's Avatar
Hi Warrjon
Cheers!
If you disconnect this wire the ECU will not fire the injectors.
