Unless your adding material I don't see how your going to go from a 76.2mm bore (larger) to a 73.8mm bore (smaller)?
Why not use a spacer / adaptor that way you dont have to worry about the bore and PCD differences?
Although you will have more complications with offsets going this route as spacers are typically 20mm min thick. So my understanding is that 32 offset goes to 52 which may limit wheel options.
I plan on modifying the fenders so not worried about going out. Its the inside that have to watch for
