Wheel question about bolt pattern / bore size
Old Nov 12, 2020 | 09:45 AM
Rescue119's Avatar
Default Wheel question about bolt pattern / bore size
Yes I've read the stickies more geared towards tire/wheel combo.. Google is 50/50 split on using 120 vs 120.65
So whats everyone's opinion on this
So factory wheels are 5 x 120.65mm (4.75) bolt pattern with a 73.8mm bore, 32 offset
Would you use or have you used a 5 x 120mm (4.72) bolt pattern with a 76.2mm bore bored out to 73.8mm?
Old Nov 12, 2020 | 10:01 AM
Greyhound's Avatar
Unless your adding material I don't see how your going to go from a 76.2mm bore (larger) to a 73.8mm bore (smaller)?
Why not use a spacer / adaptor that way you dont have to worry about the bore and PCD differences?
Although you will have more complications with offsets going this route as spacers are typically 20mm min thick. So my understanding is that 32 offset goes to 52 which may limit wheel options.
Old Nov 12, 2020 | 10:05 AM
Rescue119's Avatar
I plan on modifying the fenders so not worried about going out. Its the inside that have to watch for
Old Nov 12, 2020 | 10:17 AM
Greyhound's Avatar
Going full trans am?
If you haven't found / read it already, I think this is the best thread for any wheel related stuff;
https://www.jaguarforums.com/forum/x...-wheels-65576/
Old Nov 12, 2020 | 10:35 AM
Rescue119's Avatar
Perhaps lol
Old Nov 14, 2020 | 04:34 AM
Jim5_0's Avatar
OK if you use wobble nuts to take up the 0.65mm difference. Problem solved.
denis4x4
Oct 3, 2020 11:05 AM
Allante1989
General Tech Help
May 4, 2017 06:26 PM
jahummer
Feb 24, 2015 10:39 PM
randyb
Oct 5, 2011 12:09 AM
Jessy
Oct 7, 2009 11:53 AM
