Where can I buy Distilled Water for my Radiator? XJS V12
Old Oct 25, 2016 | 01:13 PM
Jagboi64's Avatar
Perhaps a silly question, but can you buy premixed coolant in the UK? I can get it in Canada and then there is no need to dilute the concentrate with distilled water. Just pour the premixed into the radiator and you're done.
Old Oct 25, 2016 | 01:41 PM
ptjs1's Avatar
Jagboi64,
Yes, you can get pre-mixed coolant here in the UK. As with pre-mixed screenwash there is a slight premium to buying like that.
Paul
Old Oct 25, 2016 | 02:27 PM
Jagboi64's Avatar
There is non premixed screen wash? Here There are 2 kinds, both of which come in 4 L jugs: Summer grade for removing insects that smear on the screen, and winter that won't freeze down to -40C. It's basically methanol. The most common is the winter grade, I use that year round just because I don't want to get caught with half a tank of summer fluid when it freezes.
Where I live we get lots of freeze thaw cycles in the winter, and the snow comes, melts and comes again. When it melts, everything turns to a sloppy, salty mess, so I go through a lot of fluid. I always have a spare jug in the car in the winter.
Old Oct 25, 2016 | 07:40 PM
baxtor's Avatar
Originally Posted by Jonathan-W
WHOA!
that is not distilled water that is condenser water...
IT IS SO DIRTY.... all the dust and little nats (BUGS) blow through the condenser too... bacteria grows in that filth
might as well use ditch water
I think the reference was to water dripping from evaporator not condensor. Collecting it would hardly be worth the effort but I don't see why it would not be considered "distilled" as that is more or less what it is.
Old Oct 25, 2016 | 11:24 PM
afterburner1's Avatar
Isn't rain water and snow distilled? Why don't you use 50/50 antifreeze/distilled h2o? That should reduce the cost of the water by 50 percent!
Old Oct 26, 2016 | 12:32 AM
orangeblossom's Avatar
I've ordered the proper stuff now, so I'll be using that and we have acid rain down my way, so I wouldn't even dream of putting that in.
Old Oct 26, 2016 | 10:10 AM
Jonathan-W's Avatar
you have never had to clean the filth out of one then... or a clogged one.. clogged with filth... just what I want to put in my v12 NOT
distilled
starts with CLEAN filtered water heats it to boiling... then passes the steam though pipes that are air or water cooled to condense the steam back to water... this removes mineral content and everything else...
you can buy a deionizer and it removes Ions... this makes sure that the water has a neutral PH
in any chem lab they do both...
Old Oct 26, 2016 | 11:14 AM
  #28
JagCad's Avatar
We are very fortunate around here. Water quality is excellent.
Good enough to mix with Glycol for the coolant. Not good enough for a battery. rarely, if ever needed, though. I did use some for my bench test battery. so far so good.
For my W/S washer, I merely use faucet water and car wash soap/wax. Works just fine.
The markets do sell a selection of "waters". I did buy a couple of gallons. Mostly for the containers. One per car!!!
I have a bit "two gallon?, glass wine jug" filled with faucet water. Emergency use!!!
Freeze not a problem here most of the time!!!
Carl
Old Oct 28, 2016 | 12:01 PM
Could I use Bottled drinking Water instead of distilled Water or de-ionised Water in my Radiator?
The stuff I found to-day at 17p for 2Litres has a PH of 7.8.
Old Oct 28, 2016 | 01:52 PM
  #30
These guys say you can, if it's purified.
https://www.drinkmorewater.com/disti...purified-water
Old Oct 28, 2016 | 02:12 PM
  #31
Greg in France's Avatar
NO you cannot OB. Plenty of bottled water has salts and all sorts in it, it is a selling point!
Just buy distilled or deionised, and stop worrying! Or rig up a rain butt from Orangeblossom Towers' guttering!
Greg
Old Oct 28, 2016 | 02:45 PM
  #32
Mikey's Avatar
Greg
+1
Bad choice.
Old Oct 28, 2016 | 05:35 PM
  #33
Greg
Hi Greg
I've already done the Antifreeze with the proper stuff but was thinking of getting a couple of bottles just for 'Topping Up'
And if I don't use it, I can always drink it!
Old Oct 29, 2016 | 07:37 AM
  #34
leo newbiggin's Avatar
if you go to an aquarium shop that deals in marine fish, ask them for RO water.
this is purified water that is achieved by "reverse osmosis". It is the stuff that fish perverts put in their tanks to keep expensive nemo's alive. I must say it sounds a bit extreme, but go for it as it wont do the v12 any harm. I dont know how much this stuff costs but said pervs must use quite a bit.
Old Oct 29, 2016 | 08:34 AM
  #35
Go to Halfords and they will sell you "battery top up" water for £3.50 for 5 ltrs.
Halfords Battery Top-Up Water 5L
"Halfords Battery Top-Up Water
The Halfords Battery Top-Up Water is a 5 litre bottle of de-ionised water, suitable for use in lead-acid batteries. It can also be used in engine cooling systems to reduce scaling and corrosion as well as irons, lava lamps and air-conditioning units."
Old Oct 29, 2016 | 08:46 AM
  #36
Jagfixer's Avatar
Parts stores sell a 50/50 mix, buy that and don't worry about it. You don't change antifreeze that much, even though they say every 3 yrs. Also, there is a waterless antifreeze, expensive, yes, but you never have to change it and it does not corrode the system.
Old Oct 29, 2016 | 08:57 AM
  #37
Mikey's Avatar
It's significantly downgrades the ability of the radiator to shed sufficient heat.
Bad stuff, stay away.
Old Oct 29, 2016 | 09:58 AM
  #38
Being Scottish that is not an option for me.
At Walmart full strength Dexcool is $14.27/gal 50/50 is $12.47/gal distilled water is $0.88/gal so I can have 2 gallons of 50/50 for $15.15.
Old Oct 29, 2016 | 10:01 AM
  #39
Hi Leo
You've gotta be joking haven't you!
Six XJS's + Three MGB's + A Landrover (Diesel of course Lol) and a Couple of Mercs, The Neighbours already think I've Won the Lottery.
So doing what you suggested it would only make things worse.
Old Oct 29, 2016 | 10:04 AM
  #40
Nice idea but just one little problem!
No Walmart in the UK
