Where is the charcoal canister?
Old Jun 22, 2014 | 08:13 AM
Vee's Avatar
Vee
Default Where is the charcoal canister?
I have a 96 XJS convertible with the I6.
Is it safe to assume that I'll be able to find the charcoal canister somewhere by the fuel tank under the rear of the car?
I want to check out this Rochester Valve to see if it's causing me a little bit of grief. Seems simple enough to check and replace, I just need to know where to look.
Thanks.
Old Jun 22, 2014 | 11:15 AM
Bc xj's Avatar
Try the left front fender. Access cover through wheel well. Thats where it was in my 89.
Old Jun 23, 2014 | 06:29 PM
J_C_R's Avatar
Yep. Jack it up, remove the part that covers the left front wheel well, and there it'll be (at least on my '87 V12).
While you are at it might be worth removing the cover behind the wheel and inspecting the radiator overflow tank (if that's where it is in the six).
Cheers,
John
1987 XJ-S V12
64,000 miles
Old Jul 13, 2014 | 12:15 PM
Vee's Avatar
Vee
...and that's where it was. Thanks.
My valve was going bad. I was able to suck and blow air through it.
Rakka
Nov 2, 2015 09:06 PM
42Ajd
Sep 26, 2015 07:04 PM
BlacXJRcat
Sep 25, 2015 06:43 PM
Knomad
Sep 22, 2015 04:36 AM
