Where to find replacement seat heaters?
Old Dec 25, 2014 | 07:35 PM
Safari's Avatar
Default Where to find replacement seat heaters?
I think the seat heaters in my '90 XJS are dead. Where can I find replacements?
Thanks!
Mark
Old Dec 25, 2014 | 09:35 PM
superchargedtr6's Avatar
I thought mine were too....turned out to be the fuses. I think the winshield leaked in my car prior to my ownership, and the water got to the fuse panel. Fixed that, worked the switch a few times, and they came back to life.
Old Dec 25, 2014 | 09:51 PM
Safari's Avatar
I have already gone through all of the fuses, switches, relays and grounds. Still no heat from the pads.
Old Dec 25, 2014 | 09:53 PM
Lance 99's Avatar
I googled "heated seats" and there are a lot of sites that come up. Here's one:
Seat Heater for Cars and Trucks from HeatedSeatKits.com
Old Dec 27, 2014 | 05:42 PM
malc4d's Avatar
Don't like them....always think l pooped me pants.
Old Dec 28, 2014 | 07:28 AM
Daim's Avatar
Everyone has that feeling at first. But wait until you get a bad back or your seat is icey cold. You then wish you had them in all cars!
All my cars have had factory heated seats so far... I even use them in summer in my C30... Windows open and seat heating on... Sounds gross but it keeps you a tad warmer when moving.
Old Dec 28, 2014 | 08:05 AM
Brake buster's Avatar
you probably know this,
but there are four pads, two in each seat, one base and one in the back , the drivers seat is direct feed from a fuse under the steering wheel via the switch and relay , take the seat back off and see if you have power at the multi-plug ?
the passenger seat is slightly different, in that there is a pressure pad in the seat base to stop it working if there isn't anyone sat in it , as i said, the drivers seat is always live as its assumed that the driver is sat in there to switch it on.....
the passenger seat , again , has its own fuse ,
the heating elements are not the most powerful in the world, and can take some time to take the chill off, i have never felt my seat to be ' warm ' just not cold when working
BB
Old Dec 28, 2014 | 10:19 AM
dsetter's Avatar
Also be aware that the heater controller down in front of the seat has a habit if burning out. I have used a relay and a programmable time to turn on the heat for 10 minutes. The can get very hot without the controller that related the temperature.
Old Dec 28, 2014 | 11:32 AM
Safari's Avatar
Thanks guys. I will dig into the seats and see what I find there.
Old Dec 29, 2014 | 06:07 PM
sidescrollin's Avatar
look through the junkyard til you find something with heated seats. Peel the skins and grab your parts?
Jandreu
Aug 23, 2019 11:37 AM
Xj812
Oct 26, 2015 05:04 AM
casepie
Aug 30, 2015 09:49 PM
bigw909
Aug 30, 2015 09:29 AM
Calhale
Aug 29, 2015 10:39 AM
