Wiring Diagram Help - Door Locks
Old May 11, 2015 | 01:58 PM
Vee's Avatar
Vee
Default Wiring Diagram Help - Door Locks
I've attached my proposed fix for the door lock problem I am experiencing.
The actuator keeps firing, as seen on the YouTube video:
It only does it on the passenger side. I have disconnected the actuator from the lock linkage, swapped out actuators, replaced the PD5 connector, including pins at the door, have swapped out the Door Lock Control Unit, and have tried bypassing the length of wire between PD13 and PD5. All with no luck.
Now I will try to splice into the wires leaving the Door Lock Control Unit and splice them to the wires just before they leave for the door, just past PD13. I will then cut the wires just before the new splice.
I have to assume that one of the splice points has gone bad? (LBS68-72?) The splices exist somewhere inaccessible, so I won't be able to find them.
I was concerned that this action would create new problems. Any suggestions??
Thanks!
Perhaps a short somewhere?
File Type: pdf
Old May 13, 2015 | 04:21 PM
xjsv12's Avatar
Check battery voltage on the door lock control module. If yes. Inside DLCM is two nacked relays, check how good relays soldered. You can touch each relay to activate the actuators.
Old May 14, 2015 | 10:07 AM
Vee's Avatar
Vee
Thank you for your response, I was beginning to think I wasn't going to get one.
The wiring diagram shows one wire leaving the DLCM for each of the two locks. (Wires are spliced down the line) If the drivers side door actuator is fine, and only the passengers is affected, can't I eliminate a problem with the DLCM. (I also bought a second one, and it did not change anything)
I have a plan:
1. short the Orange/Blue and Orange/Red from the DLCM right to the PD13 connector. Those are the only two wires that contain an additional splice from the Security System. It happens to be the Lock/Unlock Input wires. I'll see if that's not the problem.
2. Undo #1 and do the same for the Orange/White and Orange/Green wires, which are the Lock/Unlock Output wires.
3. Redo #1 with #2 in place.
4. If needed - do the same with the Ground.
Old May 16, 2015 | 11:17 AM
Vee's Avatar
Vee
I am very frustrated. I shorted everything to the relay.
There was no difference.
What the hell am I missing?
Old May 16, 2015 | 08:15 PM
Vee's Avatar
Vee
Problem resolved. Go here:
https://www.jaguarforums.com/forum/x...8/#post1229938
99xk8guy
Sep 29, 2025 10:51 PM
kevinl
Oct 31, 2019 06:15 PM
XJsc-guy
Nov 23, 2015 01:56 PM
DatDude
Sep 8, 2015 11:36 PM
danpop
XJ40 ( XJ81 )
Sep 8, 2015 03:23 PM
