XJR-S with FF-15 Code
Old Aug 7, 2017 | 02:38 PM
exit5's Avatar
Default XJR-S with FF-15 Code
Hi, I've had my 93 XJR-S for a few months now. Just the other day the Check Engine light came on. The code on the display reads FF-15. I believe this represents an air temp sensor failure. I checked the connections on both sensors (left and right sides). They looked good so I replaced both sensors.
I am now trying to clear the error code. I tried disconnecting the battery for the weekend. No Luck.
I then tried starting it 50 times (a hint I got from this forum). Still no luck.
Any thoughts?
Old Aug 7, 2017 | 05:09 PM
malc4d's Avatar
I just searched google and this came up. Might work..........
Fault Code FF-69
Old Aug 8, 2017 | 05:19 PM
exit5's Avatar
Thank you, I will give it a try this weekend when I return home from a week on the road. I will let you know how I make out.
Old Aug 10, 2017 | 12:59 PM
exit5's Avatar
Good news. I returned from my trip a bit early and pulled the car out of the garage so I could attempt the procedure. Much to my surprise, when I started the car the engine light was already off. I drove it for about a half hour and it remained off. So the good news is - problem resolved. The bad news - I didn't get to see of the procedure worked. Maybe next time
