XJS 1988 Steering noise
Old Oct 1, 2016 | 12:51 AM
iratcliffe's Avatar
Default XJS 1988 Steering noise
Hello everyone,
Travelling along a road which is not Freeway material, a noise very similar to plastic rubbing on plastic generates from around the dash, steering column assembly.
If you press the top of the steering wheel it stops; release and off it goes again, turning the wheel sharply in either direction on a straight road also stops the noise.
I have removed the covers on steering assembly (indicator wipers ect), disassembled the adjustable steering column, checked and tightened the column holding brackets, and every fastener I could find all to no avail.
Help would be appreciated, as I'm fed up driving this car with the hearing aids switched off.
Old Oct 1, 2016 | 05:45 AM
JigJag's Avatar
My XJ6 did this. It varied with the weather as well. I found parafin wax on the joints of the plastic trim pieces stopped it. There are also lubricants that are appropriate for plastics that you could use.
Old Oct 1, 2016 | 04:22 PM
iratcliffe's Avatar
Thanks very much for the advice Jigjag; will certainly give it a try. Regards Ian
JessN16
May 19, 2024 01:06 PM
Alexv12
Nov 18, 2015 12:24 PM
Steve M
Jul 18, 2013 04:53 AM
spuddyo
Feb 15, 2013 01:24 PM
hafferf
Jun 27, 2010 06:05 PM
