XJS 5.3 To 6.0L
Old Jun 2, 2015 | 01:26 AM
baxtor's Avatar
Originally Posted by xjsv12
I went through a transmission with low transmission from TCI and connected EZ-TCU. What I got. Very good first gear. howl of the first gear, from the first to the second has a strong leap, whistling rubber, 6 seconds to hundred. Sorry for terrible English.
your english is much better than my russian.
Did you do any adjustments to shift settings using the handheld? I found a bit of adjustment was needed (out of the box shifts almost put me in the back seat) but I am very happy with the end result.
Old Jun 2, 2015 | 03:22 AM
Jaguarman22's Avatar
About alternator and a c pump. I will send a picture.
Спасибо за предложение отправить фотографии насоса с и генератора.
Old Jun 8, 2015 | 03:26 PM
xjsv12's Avatar
Alternator pulley is from XJ V8. It is smaller for better charge on idle.
Рад слышать русскую речь из далека
Attached Thumbnails XJS 5.3 To 6.0L-2015-06-08-20.33.02.jpg   XJS 5.3 To 6.0L-2015-06-08-20.34.41.jpg   XJS 5.3 To 6.0L-2015-06-08-20.35.21.jpg   XJS 5.3 To 6.0L-2015-06-08-20.35.53.jpg   XJS 5.3 To 6.0L-2015-06-08-20.36.21.jpg
Old Jun 9, 2015 | 02:43 PM
Hi Thanks for the Photos
what pulley are you using ? on the A/C Pump or where did you get the pump
Michael
Old Jun 9, 2015 | 04:34 PM
xjsv12's Avatar
This pulley from compressor like on the pics and cutted by machinist. I do not like unused row.
I totally wrecked my XJ40 V12 in 2000 , then in 2001 X300 V12 too.
Now I have two heaps of iron, all the parts there.
I will never buy V12 sedan!
Old Jun 9, 2015 | 04:55 PM
xjsv12's Avatar
http://www.youtube.com/watch?v=YMS0N...ature=youtu.be
Old Jun 10, 2015 | 02:19 AM
Dave1109971's Avatar
nice music selection.
Old Jun 10, 2015 | 04:16 PM
  #28
I just Love the Sound of the V12
Old Jun 15, 2015 | 04:55 PM
Well New Ht Leads have arrived today so manifolds and fuel rail with recon injectors went on so know to sort out the air con and pulleys
Old Jun 16, 2015 | 07:15 AM
  #30
xjsv12's Avatar
Is your engine from X300? What will controller? X300's very difficult to connect.
Old Jun 16, 2015 | 10:11 AM
  #31
Hi Yes it is out of the X305 But Running Holbay cams the Engine will be Run By Emerald
( Home of the Emerald K6 aftermarket standalone ECU ) this will be linked up to the Gearbox ECU
been sorting out the Air Con and Alternator
Old Jun 16, 2015 | 12:47 PM
  #32
xjsv12's Avatar
Very interesting. I will fallow your project. I have X300's engine and I don't know what to do with it. I thought about mega engine, but think and dream .
Old Jun 16, 2015 | 04:19 PM
  #33
X300's are the last of the big cats with ford's input and money i believe it is the best Engine and as i beleve in using my car i have looked at all posabul ways to keep the car relabel and on the road so i have put it in my car with the 4 speed Gearbox and out Bord brakes .
i am also looking at fitting Charge coolers with a temp switch so at low speed i get the benefit of the heat and the cool air at fast speeds The Exhaust has been covered in
Titanium Heat Wrap to help keep the heat where it should be
i would like some input from other members that have realistic input for the future off keeping the cars on the road
Old Jun 16, 2015 | 05:09 PM
  #34
Jonathan-W's Avatar
Jeep I6 4.0L coil pack... Waste spark set up same firing order as one side of our V12s
have the pin out some where... 4 pins one common and 1 each for the 3 coils...
ever thought of using this as the coil pack as I thought the packaging in the V would be better
I had the pin out for the connector and they are just right for the waste spark set up on each bank
Just a thought...
Old Jun 17, 2015 | 08:18 AM
  #35
xjsv12's Avatar
Do you mean all this, suspension, brakes and etc?
Old Jun 22, 2015 | 05:22 PM
  #36
ronbros's Avatar
i love the sound of the Jaguar V12, all 12 cylinders out from one single outlet, big diameter!
Old Jun 25, 2015 | 03:28 AM
  #37
Hi well some More Photos
can any body tell me of a good place to get some wiring Diagrams for my 1988 v12 !!
Old Jun 25, 2015 | 11:32 AM
  #38
bigpigpants's Avatar
Talking
I would recommend JagDocs, The Source for Jaguar Documentation!
Regards
A.
Old Jun 26, 2015 | 02:44 PM
  #39
Originally Posted by bigpigpants
Thanks £1.89and there downloaded
Old Jun 28, 2015 | 01:52 PM
  #40
well time to finish the Rad and fans Just need to replace the Flaps and wiring
New Bush's and Rad rubbers
Fuel pipes looking at the ones that run from the Tank Under the car there a bit tatty so was wondering if any body had replaced them and if so what with
also was thinking of running them in the car ?
