Xjs air-con amplifier
Old Jul 29, 2024 | 06:51 AM
rgp's Avatar
rgp
Default Xjs air-con amplifier
Will adjustment on the cartridge size
AIR-CON AMPLIFIER affect how long the dash centre vent is active?
Old Jul 29, 2024 | 07:40 AM
Doug's Avatar
Yes, indirectly.
The dashboard center vent opens in cooling mode. It is closed in heat, defrost, and blend modes.
The amp adjustment is used to correct a difference of selected temp versus provided temp. For example, if the selected cabin temp was 75 but the system cools the cabin down to 68 degrees you'd use this adjustment to correct the problem.
If a mis-adjusted amplifier was over-cooling the cabin, the center vent would be open for a longer period of time. Adjusting the amp for correct performance would reduce the amount of time the center is open....as the system would be in cooling mode for a shorter duration
Old Jul 29, 2024 | 09:36 AM
However, my center vent has Never opened. Ever! Nor has it since I've owned the car.
I know the actuator is good from exhaustive testing.
So in spring I prop it open for AC, and in fall (pretty soon now) I let it close for winter heat.
Old Jul 29, 2024 | 09:45 AM
jal1234's Avatar
The defroster vent and center vent are interconnected mechanically. If the defroster vent doesn't close, the center vent cannot open.
The vacuum source for the center vent and the defroster vent are controlled by solenoids. So you need to check operation of the solenoids, the vacuum source and lines to the solenoids, and the electrical signals to the solenoids. Any faults will prevent proper operation of the center vent.
Jon
Steve M
Nov 25, 2022 07:13 PM
Kriss Vector
Jun 30, 2019 08:00 PM
afterburner1
Feb 17, 2019 12:12 PM
user 652867429824
Apr 14, 2017 08:15 AM
