XJS Build Question
Old 09-26-2017, 02:04 PM
brinny's Avatar
Well you live and learn. I thought that by the start of the 90s lead loading would be a thing of the past. Thanks for the info lads , that's what makes this forum the best!!
Old 09-26-2017, 04:29 PM
warrjon's Avatar
Received 2,576 Likes on 1,712 Posts
My 89 is full of lead where the roof meets the rear 1/4 panels and where the buttress meets the rear screen. I also lead loaded the RH rear guard where it had been repaired and plastic filler used.
Beauty of lead is, if done correctly it will never fall out or rust underneath.
Old 09-26-2017, 05:32 PM
Pawsnclaws's Avatar
Originally Posted by Daim
IIRC the current XF uses a different arcitecure now as it is fully aluminium. The first XF was IIRC steel bodied. There was only one Lincoln to use the Plattform and that ended long ago.
If my memory serves me, the DEW platform, or a shortened version thereof, also was the basis of the 2002-2005 Ford Thunderbird revival and the 2005-2014 non-IRS Ford Mustang. Jag XF used it until '14 or '15.
