xjs convertible fluid service
Hi All,
I am new to the forum and this is my first opportunity to post a thread.
I have a 1991 XJS v12 convertible, great car.
Recently I discovered a leak on the RH convertible top actuator, I have looked in both my owners manual and my repair manual and can not determine what type of fluid should be used to service the accumulator.
Please help.
Norm
Please help.
Norm
Hello Norm,
A Google search returned "Univis j13 or Aeroshell fluid 4". I am not ascerting this correct. The manual doesn't include info because if it is leaking, they want you to take it to the dealership. Otherwise, it doesn't need servicing.
***Update***
I'm doing some more research and the above fluids are for aircraft applications and may not be correct or are overkill.
I speculate any quality hydrolic fluid would work, but I'll defer to another member who has better information.
I beleive you can replace the seal on the pump/motor if that is where your leak is located.
Good luck!
***Update***
Good luck!
99xk8guy
Sep 29, 2025 10:51 PM
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
Nov 23, 2015 01:56 PM
Wes Steenrod
Sep 6, 2015 06:52 PM
FS[Canada]: Vancouver BC FType lease takeover
nd143
Sep 3, 2015 04:42 PM
