XJS cross member feeding the roses
Old Jan 8, 2015 | 07:11 PM
nonfinito's Avatar
Default XJS cross member feeding the roses
So, hi all
Yesterday was a great day, but for the fact that I drove my beloved XJS onto the curb at just the right speed to result in a bent crossmember, front axle, subframe - call it what you may. Nothing else has much been compromised, but the subframe is a goner.
No idea what one does in these cases: get a refurb one, go to the junkyard, try to fix/straighten the damaged one, forget it altogether?
If there's any ideas or suggestions out there in the infobahn, or if someone has a spare subframe, because some people do stock up on subframes, let me know.
Any help at this point would be greatly appreciated.
Old Jan 8, 2015 | 07:30 PM
Roger95's Avatar
Try to get a used one, suppliers such as Coventry West should be able to help.
Old Jan 8, 2015 | 07:42 PM
swayne's Avatar
Originally Posted by nonfinito
So, hi all
If you hit the curb in a manner to damage all those things be sure and check your wheel its probably bent also
Old Jan 9, 2015 | 01:52 AM
Greg in France's Avatar
Got to be a rebuild of the suspension onto a 'new' subframe, or buy an entire front subframe with suspension. The thing would not have bent unless it was nearly rusted out, anyway.
Greg
Old Jan 13, 2015 | 11:05 AM
nonfinito's Avatar
Thanks for the suggestions. I've had the funniest idea of transporting my truly excellent V12 from this vehicle to an '76 XJ12 I just bought. No idea if it's feasible though. I don't know anything and the XJ engine bay looks so tiny in comparison.
Old Jan 13, 2015 | 01:59 PM
ptjs1's Avatar
nonfinito,
Sorry to hear about the problem. That's not one I've heard before. Rusted sub-frame, that's common. But a bent sub-frame is very unusual. I tend to agree with Greg that the only way that might happen would be if the sub-frame was significantly compromised by corrosion. Either that or you must have hit something with a hell of a thump. Therefore I would also check the sub-frame mounts haven't tried to rip out of the body.
If you buy a sub-frame, buy it bare and thoroughly check it over for corrosion in the usual places, especially those hidden lower spring pan seats. You can then ensure its integrity and rebuild all the front susoension, bearings and brakes as part of the refit.
Good luck
Paul
Old Jan 13, 2015 | 06:23 PM
Bc xj's Avatar
I had a 76 XJ12L. What a great car, beautiful ride and decent handling. I do want another.
A 17 year old t-boned it and destroyed it.
steve_k_xk
Non-Jaguar Vehicles
May 17, 2016 05:29 AM
Jaguar Forums Editor
Jaguar Press release
Sep 5, 2015 10:08 AM
Sep 4, 2015 09:18 AM
Jjscruggs1
Sep 3, 2015 07:46 PM
Sep 3, 2015 09:38 AM
