Xjs isn't sparking
Old Feb 25, 2014 | 05:38 AM
John_murch's Avatar
Default Xjs isn't sparking
I had a fuel pump issue,so checked the main and fuel pump relay which are good.now I haven't got a spark at the plugs,pulled the coil lead and have a good spark here,but doesn't seem to be getting through the plug wires,any ideas anyone?.
Old Feb 25, 2014 | 06:06 AM
Mmmmmm, going out on a limb here, and assuming its a V12??.
Lift the distributor cap, turn it upside down and ensure the "carbon brush" is intact. I have had MANY with this item burnt away, and the symptoms are exactly as those you state.
If so, then a new brush is available, any Bosch, Lucas, GM cap with a spring loaded carbon brush will do the job. Down here we simply buy one from our friendly Holden (GM Aussie style) dealer, at about $5.
I would then look at WHY, and the most common reason I have found is tired and OLD HT leads.
Old Feb 25, 2014 | 08:23 AM
John_murch's Avatar
Default Xjs
Cheers grant,it's a3.6 but I'll renew cap and leads anyway.
Old Feb 25, 2014 | 08:26 AM
sidescrollin's Avatar
well if the is power going from the coil to the distributor but nothing coming out of the distributor....your problem is in the distributor lol. only difference now is you don't have to pay $60 for a replacement cap
Mac Allan
Oct 27, 2015 04:49 AM
BathoryFan
Sep 15, 2015 05:04 PM
Boeingtravel95
Sep 14, 2015 05:01 PM
Pristine97XK8Convertible
Sep 10, 2015 09:24 AM
joesoap
Sep 10, 2015 01:09 AM
