Xjs rough idle
Old Aug 10, 2014 | 11:52 AM
Jag 31410's Avatar
Default Xjs rough idle
I have a 1992 xjs with the v12. I steered driving it once the weather got nice around April. It ran fine for a while and then it was hard to start after it ran a while. Once it cooled down it was fine. Eventually it started to feel like the engine was misfiring and then it would barely stay running. I was able to limp it home. I can feel the exhaust nice and even from the passenger side exhaust pipe. The driver side sputters tremendously. I don't know where to start checking for problems. There are no obvious cracks in the pipes or hoses and everything seems to appear normal, meaning there are no obvious signs of problems. I am getting the ff36 fault code. Any help would be greatly appreciated.
Old Aug 10, 2014 | 08:41 PM
superchargedtr6's Avatar
This is a Marelli car. Most likely, you have a amp, or a coil giving up. I would start by pulling the distributor cap, and giving the rotor a good look. They seem to be the weak link in the Marelli cars, especially if it hasn't been changed in 30K miles. Seems plug gap is very critical. As the wear on the plug occurs, the gap widens, making the spark between the ring inside the distributor and rotor hotter. Checked or changed plugs lately?
Old Aug 13, 2014 | 03:40 PM
Jag 31410's Avatar
Thanks for the suggestion. I will try it and keep my fingers crossed. These cars are lucky we love them.
Bcrary3
Feb 21, 2023 04:29 AM
Rivguy
Dec 4, 2020 07:55 AM
scooternva
19
Oct 27, 2015 02:14 PM
Mac Allan
Oct 27, 2015 04:49 AM
Bowman
Sep 3, 2015 03:17 PM
