Wheels spacers recommendations for 2013 XKR Portfolio (20inch Orona Wheels)
Old Jun 6, 2013 | 11:48 AM
samy's Avatar
Default Wheels spacers recommendations for 2013 XKR Portfolio (20inch Orona Wheels)
Can you guys recommend the best wheels spacers that work with a 2013 XKR with portfolio package (20 inch Orona wheels).
I was thinking about the H&R (15mm front and 20 rear) but would appreciate your opinion.
Thanks a lot,
Samy
Old Jun 6, 2013 | 12:05 PM
rscultho's Avatar
Thanks a lot,
Samy
You don't want to do more than 15 in the rear...20mm will push your wheels out to far and you will hit the body panel lip with wheel travel.
You could do 20MM in the front, 15 in the rear. I did the H&R 15MM all around, others have done 20MM front 15MM rear. I don't know it the Orona wheels will allow the original studs to clear without cutting them. The Nevis wheels have pockets that accommodate the original studs.
FrickenJag
Jun 16, 2025 02:15 PM
PMKimpton
Aug 3, 2019 08:22 PM
al_roethlisberger
Sep 11, 2015 10:04 PM
edtexas
Sep 5, 2015 10:49 AM
obwoodie
Sep 3, 2015 07:45 PM
