$263.73 to change both air filters? (not cabin)
Old Sep 25, 2020 | 06:49 AM
Stuart S's Avatar
Here we go again with K&N air filters!
See this definitive thread from 2014;
https://www.jaguarforums.com/forum/w...d.php?t=119498
The OEM engine air filter on my 1960 Corvette was foam bathed lightly in oil, similar to today's K&N filter. When I swapped out the original 283/230HP engine in 1965 for a 1965 327/365HP crate engine (WOOHOO!!!) the OEM filter was a paper element. Oiled foam is ancient technology. I learned my lesson after falling for K&N's marketing hype and buying 2 for my 1993 600SL. A waste of money IMHO. A high quality paper filter works better and costs less.
If the K&N oiled foam method was better, manufacturers would have continued to use it after the '60s.
Stuart
Old Sep 25, 2020 | 10:52 AM
Cee Jay's Avatar
"definitive"......
HAAHAHAHAHAHAA!
Sorry, that was rude. I do apologize.
Old Sep 25, 2020 | 11:17 AM
Stuart S's Avatar
If you read that entire thread, I think you'll agree that there's not much more that can be said, either pro or con, about K&N air filters without being repetitive. That makes it a definitive thread.
Old Sep 25, 2020 | 11:39 AM
Cee Jay's Avatar
Any conclusion would need to have an outcome, either positive or negative. A "Well, either way is okay" is not definitive.
Old Sep 26, 2020 | 12:26 AM
pk4144's Avatar
Gotta say for what little it's worth I agree with Stuart on the filters.
I've read pros and cons on the KN, but LOTS of nightmare threads about MAF sensors on these cars. My thinking: stay with the OEM filters . Plus, I feel like I read a comment from Brutal (who's off this group?), pointing out that the sensors ARE tricky, and something about how using not only OEM but MATCHED filter pairs was the way to go. Honestly, I've never had an issue or thrown a code on that and at this point I don't want to start. So I'll pay the crazy price to not have to worry for a few years.
Old Sep 28, 2020 | 12:17 PM
gkubrak's Avatar
I've had K+N filters for 3 years now. No issues as long as you clean them out every now and then.
There was a P0101 code that always came up, but I was able to pinpoint that to an intake air leak, not the filters, not the MAF sensors.
Also, getting the filters 'checked' has the same labor cost as getting them 'replaced'. There's no way to check them out without doing all the work anyway. Unless they are boroscoping them.
If you plan on doing it again while you own the car, you might as well do it yourself now and learn the procedure.
Old Sep 28, 2020 | 02:11 PM
pk4144's Avatar
When I had them checked but not replaced I was not charged.
Old Sep 28, 2020 | 02:30 PM
  #28
pk4144's Avatar
When I had them checked but not replaced I was not charged. They removed one and said it was OK.
Old Sep 29, 2020 | 10:36 AM
bocatrip's Avatar
Not to sidetrack..... Is there a need to check my engine air filter with 12,000 miles on the odometer on a 2010 XK? I’m sure all filters are original. How about the A/C filter? Thanks all.
Old Sep 29, 2020 | 01:57 PM
  #30
jahummer's Avatar
I have found the cabin filters on every car I’ve checked to be in need of replacement every year. As for the intake filters, it’s likely environment will determine that. If you drive through a lot of dirt and dust they are going to clog up. Mine were like new after over 50,000 miles done,
Old Sep 29, 2020 | 02:18 PM
  #31
bocatrip's Avatar
Is the A/C cabin filter an easier replacement than the engine air filter?
Old Sep 29, 2020 | 02:22 PM
  #32
80sRule's Avatar
EXTREMELY. It's under a little panel up near the washer bottle spout. Remove that plastic panel from the top, then its under a flip lid. Like 5 minutes if you take your time.
Old Sep 29, 2020 | 02:40 PM
  #33
bocatrip's Avatar
Thank you for your help....Just got off the phone with Jaguar Parts....Does $87.29 sound right for retail on the A/C cabin filter? (2010 XK Coupe 5.0) I Didn't do any research and I always go with OEM. Just wanted to make sure. Thanks.
Old Sep 29, 2020 | 03:11 PM
  #34
80sRule's Avatar
I bought one on Amazon aftermarket and it fit and performs great.
$16 and fits your 2010 as well:
Amazon Amazon
The part is C2P2410, and it appears you can do better than that price; $66 here is my to the door price.
https://www.jaguarparts.com/oem-part...UtMGwtdjgtZ2Fz
Old Sep 29, 2020 | 04:47 PM
  #35
KrazyIvanUSA's Avatar
Originally Posted by jahummer
It’s likely mostly labor. Remove both front wheels, remove front wheel liners, remover filter housing screws and covers, slide out filters and holders, install new filters and reverse.
now if you are doing yourself, you can just do one side at a time and turn the steering away to reveal the front liner, undo the liner screws and fold it back, open the filter house and wiggle the filter assembly out.
Chances are the shop is not going to want to take the risk of cracking or breaking the wheel wells by folding them back and will remove them completely to get access.
Old Sep 29, 2020 | 04:59 PM
  #36
Cee Jay's Avatar
Also this one:
Old Sep 29, 2020 | 09:14 PM
  #37
gkubrak's Avatar
I wouldn't pull them back for risk of having them flop around and get dust/debris into the exposed intake boxes.
Old Sep 29, 2020 | 10:57 PM
  #38
pk4144's Avatar
For the Cabin Air Filter(also sometimes called the pollen filter on these cars): Yep, super easy. I get a Beck Arnley one on Ebay, about thirty bucks. BUT... if I go get one at a local Jag dealer, it's like forty and change. Who's suggesting that crazy price?
There are two "threads" of advice here, so pay no attention to those talking about "pulling back flaps." Those are for the engine air filters-- totally different operation.
Old Sep 30, 2020 | 08:19 AM
  #39
Stuart S's Avatar
For details, with photos and cabin filter choices, see the "Sticky" in the XK/XKR - 'How To' / DIY Repair & Maintenance FAQ under AirCon:
https://www.jaguarforums.com/forum/x...enance-227403/
P.S. It's another definitive thread, this time from 2013.
Old Oct 3, 2020 | 09:32 AM
  #40
StiggyMac's Avatar
Wow, that’s a crap ton of work just to get to those filters.
