07 xkr passing gear
Old Jul 27, 2019 | 11:57 AM
Canadacat's Avatar
Default 07 xkr passing gear
At 50 mph when I get on it it seems to only drop down 1 gear and only hits 3500 , is this right? Lower speeds rpms much higher,and yes this is dsc Trac mode.
Old Jul 27, 2019 | 03:43 PM
Cee Jay's Avatar
Give a pull on the left paddle, if it goes down another gear then it's possible. These cars learn driver patterns and adapt to them.
Maybe do a hard reset and then drive the **** outa it for awhile, it'll learn that you want to beat on it.
Old Jul 28, 2019 | 03:26 PM
Ranchero50's Avatar
Yep. above 3500 it'll just pull in the next lower gear. Whack the shifter over and you'll get another and it won't want to upshift. Drop in a set of 3.58's and it's not a big deal.
Old Jul 29, 2019 | 06:21 AM
Reverend Sam's Avatar
What does that mean?
Old Jul 29, 2019 | 09:18 AM
kj07xk's Avatar
I think he means to change the gear ratio in the 4.2L diff, which is not an ediff, so fairly straightforward.
Old Jul 29, 2019 | 05:09 PM
Ah... I've messed with my differential enough. I'm not going to do anything else to it unless I'm forced to.
Old Jul 29, 2019 | 09:39 PM
winstonsalemncxk's Avatar
I see you are in DSC track mode. Do you also have the shifter in the "S" setting for sport? If you want the car to hold revs, shifting it into S is a must.
JimC64
Apr 19, 2022 10:12 PM
sklimii
Memorial Section
Mar 23, 2018 05:52 PM
billm
Mar 20, 2013 10:07 PM
jagman96
Sep 28, 2012 12:04 AM
Blanco Gato
May 28, 2011 10:24 PM
