2007 XK Bluetooth Module ECM Issue
Old May 13, 2024 | 06:25 PM
RickXK3018!'s Avatar
Default 2007 XK Bluetooth Module ECM Issue
Hello Fellow enthusiasts. Question, would a later model BTooth module (eg. 2012 ECM) work in a 2007 vehicle? This year, my BT cannot connect/pair with phones this year. Maybe the mobile phone IO is too advanced for the current ECM? I have had a service centre reflash the S/W on the unit without resolve.
So, am thinking of hunting for a replacement and I believe from 2012 onward, the interface is improved and may work with current mobile phone IOs.
Thank you in advance for your help & support.
Old May 13, 2024 | 08:50 PM
Sean W's Avatar
Here are the part numbers and they're backward compatible:To VIN B07046: C2P11342 (6W83-10D893-AE)
B07047 to B15111: C2P12058 (6W83-10D893-AF)
B15112 to B27986: C2P14821 (6W83-10D893-AG)
B27987 to B32752: C2P17620 (9W83-10D893-AA)
B32753 to B36862: C2P20239 (9W83-10D893-AB)
Also look at the attached to troubleshoot. Good luck
File Type: pdf
Old May 14, 2024 | 12:27 AM
guy's Avatar
guy
Peterborough…. I drive by your town often.
Do note that the bluetooth modules do seem to have an operational lifespan for many. Though not in my case.
However, I have not had any issue with connecting any phone device as yet.
Of course the bluetooth specification has significantly changed over these many years. Its interesting to me how well the backwards compatibility has performed. That is “Call Control Profile” still sits at 1.0 and is currently not identified as deprecated.
Cheers.
Old May 14, 2024 | 02:50 PM
Thank you Sean. Greatly appreicate the detailed response. My VIN is before these, so am wondering if these are backward compatible to my VIN #02143?
Old May 14, 2024 | 06:55 PM
Sean W's Avatar
Re-read my post. The very first X150 Vin ended with B00001 so you are in the initial range. )"To VIN B07046: C2P11342 (6W83-10D893-AE)" You might have missed it as it's on the first sentence I wrote. At any rate my comments still apply. They are interchangeable. Good luck!
hwverwoerd
Jul 4, 2024 11:15 PM
JustNiz
Aug 21, 2023 02:06 PM
DarkCusp
Jul 5, 2023 03:53 AM
vnewtonXK07
Jan 18, 2023 12:07 AM
mpaff
Oct 21, 2018 07:53 PM
