2007 XK Convertible Top - Rear Glass Seperating
Old Dec 10, 2021 | 04:53 PM
M1redskin's Avatar
Default 2007 XK Convertible Top - Rear Glass Seperating
Heh guys, I got the above car and about the 30% of the rear glass has separated from the convertible top. Was looking for some recommendations on glue or repair procedures. I realize the original process is probably a heat pressure
applied process. The best suggestion I have so far is to try a product from 3M Panel Bonding Adhesive 08115, Any other suggestions would be appreciated. Thanks!
Old Dec 10, 2021 | 05:00 PM
Arminius's Avatar
Do a little search around this forum.
Buy a new top. Aftermarket.
Sorry about no cheap solution, Hermann
Old Dec 10, 2021 | 06:49 PM
JackJohn's Avatar
Search the forum, several folks on here have re-glued their back window to the top. The glue of choice seems to be Rhino Glue.
Old Dec 10, 2021 | 07:01 PM
Stuart S's Avatar
It's an easy, DIY repair. Read this:
https://www.jaguarforums.com/forum/x...le-top-247979/
Old Dec 10, 2021 | 07:36 PM
M1redskin's Avatar
Thanks Herman! Nothing to lose by trying glue first I figure. Appreciate the help!
Old Dec 10, 2021 | 08:09 PM
M1redskin's Avatar
Thanks for the help - got some $65 (set of 6) Suck and Clamps on order and will try the 3M Panel Adhesive 08115 and see how it goes.
Old Dec 10, 2021 | 11:32 PM
Stuart S's Avatar
Don't use the 3M adhesive. It's messy and failed after a few months. Rhino Glue is still holding up after several years. Did you read the entire thread in my post #4, above?
Your car, your money, your choice. Good luck!
Old Dec 11, 2021 | 12:35 AM
M1redskin's Avatar
Yea I did read that but they didn’t identify the type 3M used. I might the Rhino route yet but thanks for pointing that out.
Old Dec 11, 2021 | 05:05 AM
Stuart S's Avatar
If you read my posts, you would have seen the 3M products that I used. The first two didn't work for me:
1. 3M 08682 Single Step Primer (small bottle).
2. 3M 08609 Windo Weld Super Fast Urethane Black Cartridge.
3. 3M 08984 General Purpose Adhesive Cleaner.
See the DIY Sticky at the top of this Forum.
Old Dec 11, 2021 | 07:16 AM
M1redskin's Avatar
Great! I was looking for that DIY sticky note that was mentioned in the email and I couldn’t find it if that’s where this message was at. I read down through a number of emails though and I did not see these pictures but anyways what you used is a different 3M product that from what I was advised by a company that does convertible top replacement. Thanks for response again.
Old Dec 11, 2021 | 09:50 AM
jbmi's Avatar
Rhino glue and Suction Clamps really worked for me. Follow directions on the glue container and Suction instructions.
I had about the same separation except mine was on the bottom.
One thing I did do after the glass was reglued I took the second bottle in the Rhino glue package (Rhino Gel Glue) and very carefully
went around the entire window using the gel almost like caulking pushing the glue between the top and the glass forcing the gel into the space between
the two with a pointed wood dowel, take it slow and you can get a really nice seam.
Old Dec 15, 2021 | 01:27 PM
Amazen's Avatar
Default Top fix
If the bottom is separating the glue works very well are used both gorilla glue as well as the 3M glue. Not so lucky if the top is separating. If you look you can see that it’s actually a piece of material glued to the roof and then glued to the window you can see that on the on separated section. What I did was use gorilla tape as close as possible to the color of your roof. Cut the gorilla tape to slightly less than half an inch in width. Put tape on underside of the roof folded with the other side connecting to the glass . Any portion of the tape that does not adhere to the roof immediately are used gorilla glue to ensure firm attachment. This provides the flap for the window to connect to as it will not connect directly from the roof to the glass as the distance is too far . Mine has held up for over six months now it takes a little cleanup with a razor blade to ensure a smooth straight line as well as to clean up any excess glue. Be sure to not get any on the vinyl roof as it’s very difficult to clean off. I’ll add a photo of mine later.
Seil39
Nov 8, 2019 07:37 PM
Pash
Mar 3, 2015 10:23 AM
kieran
Nov 13, 2012 07:34 PM
XKuser
Jun 3, 2012 10:17 AM
