2007 XK P0410 code
Old Jan 15, 2017 | 09:30 PM
Darve62's Avatar
Question 2007 XK P0410 code
Read somewhere this was not a real trouble code on 07 XK so I reset. Code returned and I now can not locate fuse to check for real trouble. Any suggestions on where to look. There is a fuse labeled active exhaust, think that could be it? Will check in AM. Checked active exhaust fuse it was ok. Will try and locate [secondary injection switch valve a] and try and see if it is shorted.
