2007 XK Relay SChematic
I cant seem to find the EXACT Relay Names/Locations for the 3 fuse boxes in my 2007 XK Convertible. Does anyone have a diagram/picture show what each relay is. I have teh fuses but not relays.
If not in handbook maybe in workshop manual or on JagRepair.com - Jaguar Repair Information Resource
Sometimes jag use more than one name for the same thing (yes, daft) so be prepared.
You have to look at the wiring diagram
Power Distribution
Central Junction Box
Auxiliary Junction Box
Each will have the relay named (probably abbreviated) and the relay number. I believe the relay numbers are embossed on each box but not 100% certain. For relays that might be mounted elsewhere, you'd need to search the wiring diagram based on the issue you're having.
