2007 XKR engine in an XK
Old Oct 5, 2023 | 09:21 AM
neilca's Avatar
Default 2007 XKR engine in an XK
I have come across a 2007 XK that was overheated and apparently killed the engine. I am looking at options for the replacement and was wondering if can I buy a used engine from a 2007 XKR and replace the cooked one? Pretty sure the XKR ECU would have to follow the engine into the chassis. What say you?
Old Oct 5, 2023 | 09:30 AM
Cee Jay's Avatar
The ECU and probably the instrument cluster also, if I remember right. That means also all the keys and such. I think.
Old Oct 5, 2023 | 09:57 AM
neilca's Avatar
This is why I hate dealing with the new cars, the total integration makes any changes difficult. I can see changing ECU for engine management and yes I see the key too but the instrument cluster? Why the instrument cluster?
Do you think the XK ECU could be reflashed for the supercharged engine?
Old Oct 5, 2023 | 11:11 AM
Cee Jay's Avatar
Now you're beyond me. There are several guys in here that can answer this completely accurately, I'm not one.
Let's wait a bit, someone will come along.
Old Oct 5, 2023 | 11:22 AM
neilca's Avatar
I spoke with the folks at the Mina Gallery and he said the XK ECU didn't have all the parameters the XKR ECU had so his tuner couldn't be used on the XK ECU to overcome the deficit. Said get a car kit from the junkyard that includes the ECU and harness with the engine. Keys would have to be reprogrammed.
Old Oct 5, 2023 | 12:48 PM
sony2000's Avatar
Default Scrap XKR
Wouldn't the block and heads from the XKR replace the block and heads, from the XK.? And everything else stays the same on the XK..
Old Oct 5, 2023 | 01:16 PM
neilca's Avatar
The XKR has a lower compression ratio for the supercharger.
I want to replace the XK engine for the XKR to get more horsepower.
Old Oct 5, 2023 | 01:46 PM
mhminnich's Avatar
It's a lot more than engine and ecu. Best to go back with the NA engine and or save for an R.
Old Oct 5, 2023 | 02:15 PM
AlexJag's Avatar
Sponsor
XKR ECU is different but is easily programmable and can be matched to your car. Will it work without issues? That I don't know, but it might not be worth the hassle..
__________________
2008 XKR Convertible, (mods: AlphaJagTuning ECU Tune , 1.5lb pulley, (200cel cats( are now melted), xpipe, Bosch 001 pump, 180 Thermostat.
Drag strip : 7.9sec 1/8mi 90 MPH . 1/4 mile 12.55 at 112.98mph
432rwh Dyno on Mustang Dynometer , Approx 511 crank HP.
2013 XJ 5.0 SC (Alpha Jag ECU, TCU tune, crank pulley), 600+ HP, 11.6 sec 1/4th mi 122mph, 7.6sec 1/8th mi
2018 Jaguar F-Type (AlphaJag ECU TCU, lower upper pulleys intake) 10.77 ,131mph ,700hp
Old Oct 5, 2023 | 05:33 PM
NBCat's Avatar
Would be much simpler and cost effective to find a used AJ34 and have it installed.
Old Oct 5, 2023 | 08:58 PM
sony2000's Avatar
One alternative if it is not a go, to switch for a complete turbo engine is that the block could be used in the XK and send out the old heads to be rebuilt.
Then the XKR heads could be sold off, along with the turbo. I am assuming the lower compression ratio in the R is achieved by the heads only.
Old Oct 5, 2023 | 09:01 PM
NBCat's Avatar
There is no 'turbo' on the AJ34 or AJ34S.
Lower compression can be achieved by different piston shapes, not just the cylinder head.
Old Oct 6, 2023 | 05:06 AM
steve_k_xk's Avatar
I went through this with with many options being considered.
A n/a 5l got ruled out almost immediately along with a new gearbox being required (ZF6HP28) different bellhousing compared to the 4.2l and the nightmare of trying to get all the components to speak to each other was beyond me .
The 4.2 s/c was also considered however would have only went down this path if I was able to find a front cut as there's a little more then just dropping the engine in .
The Aston Martin 4.3 and 4.7 were also considered as these can get goinh with some modifications but at 20k or so for a 4.3l it didn't make sense.
I finally went down the track of a aj41 (2007 4.4 range rover engine) with a few modifications like drilling out oil pan for dipstick , swapping out injectors/ sump & timing cover it's pretty straight forward (If I could do it again I would have changed my camshafts to 256° items then perfect!)
All in all it runs over 102mph and 13.5 down the 1/4 mile now so not quite 4.2s/c but on par with 5l n/a .
Just some food for thought for someone who has been in this situation
Old Oct 6, 2023 | 09:51 AM
Sean W's Avatar
yes you an refresh the ECU. The instrument cluster is the gateway for the high speed and medium speed Controller Area Network (CAN) and is also connected to the Local Interconnect Network (LIN) bus to the start control unit and the steering wheel module, along with a multitude of other modules and the CJB. If you don't have it paired, car no go.
I don't know your budget but you would prolly save $$$ parting out your XK and buying an XKR. Good luck and lets us know how you get on.
Old Oct 6, 2023 | 06:29 PM
sony2000's Avatar
The bore and stroke on the XK is exactly the same as the bore and stroke on the XKR . Page 266 of the owner's handbook.
Bore 86.0mm and stroke 90.3 mm.
So if the turbo project become unwise, I repeat the idea of using the old heads on the XKR block. The compression most likely will be the same. Plane the old heads to make sure they are not warped for instillation on the XKR block.
Old Oct 7, 2023 | 10:35 AM
neilca's Avatar
This spells out why I hate working on modern cars. You can't change a dang thing.
I think my plan is to replace the engine with a stock junkyard take out. Keep the old engine and maybe rebuild it and add a supercharger for a 2003 era Land Rover Discovery project I had been planning.
Old Oct 9, 2023 | 05:13 PM
CA Jag's Avatar
It doesn't sound like you own the XK. If not, save up and buy a good XKR. Get the SC engine plus better suspension, brakes and exhaust.
Old Oct 10, 2023 | 07:59 AM
neilca's Avatar
It is true I don't yet own the XK but, it is to be gifted to me. I am not sure the XKR is what I would inevitably get. Perhaps the XK would fill the bill as is.
Lothar52
Oct 9, 2024 12:48 PM
JpmorrisUM
Sep 19, 2023 08:47 PM
simongulliver
Dec 16, 2020 01:05 PM
elindo
Nov 28, 2019 02:58 PM
