2007 XKR rear brake pad change question...
Old May 3, 2016 | 04:25 PM
multistrada74's Avatar
Default 2007 XKR rear brake pad change question...
hey all. i just did my front pads and to push the piston back in, all i needed was a c-clamp. will that work in the rears too, or do they require a piston retraction tool? hopefully not, but i wanted to be prepared before i started the job. tnx for any help in advance.
Old May 3, 2016 | 04:40 PM
Sean W's Avatar
All the info you need right here:
https://www.jaguarforums.com/forum/x...cement-136031/
Old May 3, 2016 | 05:21 PM
tnx!
Old May 4, 2016 | 06:13 AM
steve_k_xk's Avatar
Yes you will need the piston retraction tool to perform the rear pad change
Old May 4, 2016 | 09:53 AM
Slee_Stack's Avatar
Do all MY use the same size brakes and change procedure?
Old May 5, 2016 | 04:28 AM
steve_k_xk's Avatar
The xkr have larger brakes than the xk although the procedure is identical as both have electronic handbrake and require the rear piston retraction kit
DJS
May 23, 2017 04:37 PM
Blkv8s
May 11, 2016 10:19 PM
Bhpbug
May 3, 2016 12:26 PM
EZDriver
Apr 12, 2016 06:30 PM
clivedavies
Apr 7, 2016 10:21 PM
