2008 XK EPC parts catalog
Old Feb 24, 2024 | 11:57 AM
Andwell's Avatar
Default 2008 XK EPC parts catalog
Does anybody have the EPC for a 2008 XK? a plastic vacuum line has broken and I cannot find a part number for it. It attaches to the throttle body elbow and one line goes to a vacuum reservoir.
Old Feb 24, 2024 | 12:17 PM
ram_g's Avatar
I cannot answer your original question but in the interim, vacuum line repair sleeves are readily available. See for example
Amazon Amazon
There are many other combination kits.
Old Feb 24, 2024 | 12:34 PM
Andwell's Avatar
Thanks for the information. I will do that.
Old Feb 24, 2024 | 03:43 PM
panthera999's Avatar
Fairly typical to fix these with rubber line. The old line heats and gets very fragile, but the connectors last much longer.
Suggest you leave a half inch next to each connector to slide into the rubber vacuum line. A dab of flexible sealant around the end is a good idea.
You can also adjust the actual length of the replacement to get into places better than the relatively stiff fragile line
Make sure the check valve is oriented in the right direction.
Old Feb 25, 2024 | 10:53 AM
McJag222's Avatar
C2P3421 - JAGUAR HOSE
Number 8 in the diagram.
https://parts.jaguarlandroverclassic...3421-hose.html
Old Feb 26, 2024 | 05:28 AM
guy's Avatar
guy
Yeah…. I think I wouldn’t be purchasing a chinesium vacuum line…
Old Feb 26, 2024 | 11:08 AM
clubairth1's Avatar
Community Influencer
You got good answers but if you do still want your own JEPC I have uploaded the latest version as a compressed archive?
Looks like the files will still be there for 22 more days.
Compressed JEPC
Are you aware that it won't work anymore because they killed Flash player? We have a replacement and it's called JPART. Free and on this forum. It allows us to continue to use JEPC without needing Flash player anymore.
Rjhoy02
Mar 22, 2023 06:22 AM
mosesbotbol
Jan 27, 2022 03:22 PM
Desertdawg
General Tech Help
Dec 13, 2020 02:53 PM
