2008 xk heater hot then cold
Old Nov 25, 2018 | 12:27 PM
daveinfw's Avatar
Default 2008 xk heater hot then cold
2008 xk. The heater works good when I first start the car then if I stop the car turn it off for a few minutes it only blows cold. Got any suggestions.
Old Nov 25, 2018 | 02:30 PM
I've moved your post to the correct location.
Don't forget your intro in the new members section.
Old Nov 25, 2018 | 11:14 PM
Cee Jay's Avatar
Check coolant level?
Old Nov 26, 2018 | 07:32 AM
jagtoes's Avatar
Yep 1st place to look
Old Nov 26, 2018 | 08:10 AM
Ranchero50's Avatar
I would verify it's not in the automatic temp controls by forcing the system to full heat by setting the temp to 85` and forcing the fan to run in manual.
Might also be worth while to check for any HVAC codes with a good OBDii reader. These cars are pretty intelligent and will know when things aren't right even if they don't pop a warning on the display.
AndyT
Nov 24, 2018 03:51 AM
jbottomley
Nov 22, 2018 12:15 AM
Milowokie
Nov 15, 2018 09:09 AM
bendebusk
Nov 14, 2018 10:03 PM
Mr T
Feb 19, 2008 08:26 AM
