2008 XK pad replace
Old Nov 28, 2013 | 10:10 AM
Pringlejc's Avatar
Smile 2008 XK pad replace
Could use any tips/traps for brake pad replacement on 2008 XK front calipers?
Will tackle the rear after we find the caliper piston wind tool, no luck locally yet.....Thanx JC
Old Nov 28, 2013 | 12:37 PM
CleverName's Avatar
If you have done pad replacements in the past, you will find no difficulty on the fronts of the Jag.... It follows the standard practice.
One tool needed to pull the guide pins is an allen head socket (sorry, don't recall the size), so as long as you have that, it is straight forward.
BOL Vince
File Type: pdf
Old Nov 29, 2013 | 12:29 PM
jhdee's Avatar
The allen head is 7mm.
Old Nov 30, 2013 | 08:49 AM
Pringlejc's Avatar
Appreciate the pdf and socket size!
Forcedair1
Sep 8, 2025 01:57 PM
PMKimpton
Aug 3, 2019 08:22 PM
al_roethlisberger
Sep 11, 2015 10:04 PM
KarimPA
Sep 3, 2015 07:32 PM
OkieTim
Sep 2, 2015 12:48 PM
