2008 XKR Battery Change
Old Sep 24, 2021 | 01:30 PM
YYC guy's Avatar
Default 2008 XKR Battery Change
Hi All,
I am going to change the 6 year old battery on my elderly neighbors 2008 XKR. It looks pretty straight forward besides removing the luggage compartment cover. Any suggestion on how to do that with out damaging it?
He also has a problem with his roof not closing all the way but with research on this forum I have several things to check first.
I have to say the early X150 seems a little harder to work on compared with my 01 XKR but that is just probably familiarity.
Have a good weekend.
Old Sep 24, 2021 | 04:56 PM
V7Sport's Avatar
Originally Posted by YYC guy
Hi All,
Some people use a couple of 2x4s on the floor to help skid the old battery out and new one in. I just lifted them out/in and had no problems (and I’m old).
I put a little silicone grease on the terminals after installing to prevent oxidation. You’ll have to reset the parking brake so follow the pop up on the binnacle message console. Some people have to reset the windows too I think. See the drivers manual.
I know nothing on resetting the top to close.
Good deed for your helping your neighbor!
Last edited by GGG; Sep 27, 2021 at 02:56 AM. Reason: Split the QUOTE from the REPLY
Old Sep 25, 2021 | 01:11 AM
kj07xk's Avatar
Hi All,
First, unhook and let the ‘window shade’ luggage cover retract.
Then just rotate it a bit until you can lift it up and out of its track.
Now follow the procedure in the previous post to remove the cover over the battery and electronics.
Yeah, that battery is a heavy sucker, and not in a convenient location over the rear axel.
Old Sep 27, 2021 | 01:28 PM
YYC guy's Avatar
Thanks to V7Sport and kj07xk for your help. The the battery change out was easier than expected. I also installed a maintainer while I was in there.
The roof reset was really easy. All in all a good couple of hours, only now I want an XK150!
Regards,
Karl
XKGuy
May 18, 2013 02:13 AM
GRONJ43
Mar 8, 2009 11:33 AM
