sorry about hurting feelings mate. I was just trying to figure out your age due to how expressed your frustration. Hope all the help gets it all fixed for ya
What I did was drill a hole, tap the hole and refasten with a bolt - I also covered the connection with paint to protect it from moisture. Make sure you use the right drill size for the tap, the frame is not really thick so be careful when tapping the hole, there won't be a lot of threads after you are done. I think I used a 5/16 of maybe 3/8 bolt.
can you tell me where is that ground on left ( driver) side? behind the front wheel like passenger side ? i can’t find it
thanks
thanks
I've never actually looked for ground G01 as my problem was with the passenger side - according to the manual:
G01AL Ground point 1 Lower LH front of engine compartment FRONT LEFT
G01BL Ground point 1 Lower LH front of engine compartment FRONT LEFT
G01BR Ground point 1 Lower LH front of engine compartment FRONT LEFT
You might have to take the engine undercover off to look at the chassis, or it could be behind the wheel.
