Adaptive Headlight Issue
Old Feb 9, 2023 | 08:26 PM
mopars&jags's Avatar
Default Adaptive Headlight Issue
New 2011 Jaguar XKR owner here,
I recently purchased the car and only one headlight assembly is functioning. The driver's side high-beam, low-beam, and front turn signal do not function at all.
Can someone please give me an ordered list of things I should check? I've been reading on here, some people have mentioned the ballast, fuses, and grounds.
The car does have adaptive lighting.
Thank you!
Old Feb 9, 2023 | 11:17 PM
McJag222's Avatar
Originally Posted by mopars&jags
New 2011 Jaguar XKR The driver's side high-beam, low-beam, and front turn signal do not function at all.
Assuming the turn signal lamp is ok I would check the ground lug (the grounds for the lights are on the opposite side to lights (go figure) one for the L/S is on the chassis behind the right wheel. Not sure where on the chassis the R/S ground lug will be - could be under the wheel arch cover. I posted about my issues here this is for the 2009:
https://www.jaguarforums.com/forum/x...cators-240302/
Old Feb 9, 2023 | 11:20 PM
McJag222's Avatar
2010 Electrical guide PDF::
http://www.jagrepair.com/images/Elec...al%20Guide.pdf
Old Feb 11, 2023 | 07:38 PM
Thanks for the help!
Old Feb 12, 2023 | 02:06 PM
McJag222's Avatar
Any luck with the issue?
RedRider48
Jul 4, 2022 08:17 AM
resident_fng
Jul 3, 2022 12:33 AM
cs81srq
Dec 20, 2020 10:50 AM
AlexKeyWest
Jun 30, 2019 03:16 PM
cadmium
Apr 29, 2012 04:43 PM
