2008 XKR: possible to swap 6HP26 for a 6HP28?
Old Oct 15, 2020 | 09:58 AM
JustNiz's Avatar
Default 2008 XKR: possible to swap 6HP26 for a 6HP28?
Anyone know if its even possible to replace the OEM 6HP26 trans with a 6HP28? I understand they are both physically identical, so a 6HP28 should just drop in, but what about all the programming and mapping?
There's a couple of reasons I want to do this:
1) Shifts on the 6HP28 are a LOT smoother
2) More max hp/torque headroom. the 6HP26 is rated for only 443lbf.ft max, car is already making 420, and I've been thinking about a twin screw upgrade and several other performance mods that will take me at least into the high 500's.
Old Oct 15, 2020 | 12:15 PM
jahummer's Avatar
There are some who have manage considerably more torque on the 26, there are also a number of aftermarket torque convertors available. I do not think the 28 will work because as far as I know, the TCM/TCU is completely different.
Old Oct 15, 2020 | 01:09 PM
Kongo1's Avatar
Guessing that some of the harsher shifting was smoothed (mapped) out with the newer TCM??
Old Oct 15, 2020 | 02:08 PM
jons's Avatar
Probably not helpful as I have no idea about compatibility, but, I think if anything you'd want to go straight for an 8HP as it can do what you're asking. If you're going to go through the trouble to replace a transmission at all you might as well go all out. It can be found in the F-Type.
Old Oct 15, 2020 | 04:00 PM
AlexJag's Avatar
Sponsor
I'm I'm pushing over 500 on 08 Xkr And at least that much in torque if not more, And my shifts are butter smooth . You might just need a transmission adaptation procedure done
__________________
2008 XKR Convertible, (mods: AlphaJagTuning ECU Tune , 1.5lb pulley, (200cel cats( are now melted), xpipe, Bosch 001 pump, 180 Thermostat.
Drag strip : 7.9sec 1/8mi 90 MPH . 1/4 mile 12.55 at 112.98mph
432rwh Dyno on Mustang Dynometer , Approx 511 crank HP.
2013 XJ 5.0 SC (Alpha Jag ECU, TCU tune, crank pulley), 600+ HP, 11.6 sec 1/4th mi 122mph, 7.6sec 1/8th mi
2018 Jaguar F-Type (AlphaJag ECU TCU, lower upper pulleys intake) 10.77 ,131mph ,700hp
Old Oct 15, 2020 | 05:02 PM
MarkyUK's Avatar
Keep your current tranny and ensure it has had the required ZF fluid/filter changes (IIRC 50k miles then ever 30k)
Do a hard reset after the tranny service or else buy something like a DTUK tranmission flash and you can reset the TCU whenever you want
Old Oct 19, 2020 | 11:19 AM
Panthro's Avatar
You could also look into swapping in some of the 6R80 parts to upgrade your current transmission, like the Aussie guys/gals regularly do
Majik Lasers
Apr 7, 2015 01:47 PM
Copronymous
Oct 8, 2014 02:53 PM
rickross
Feb 16, 2014 04:27 PM
loaks111
Aug 31, 2008 12:25 PM
