2008 XKR-S and XKR-Portfolio
Old Aug 25, 2011 | 05:20 PM
dd823's Avatar
Default 2008 XKR-S and XKR-Portfolio
What are the differences between an XKR-S and XKR-Portfolio
Old Aug 26, 2011 | 03:49 AM
GrahamS's Avatar
The 2008 XKR-S was a limited edition 'higher performance' version with the bigger Alcon brakes, raised top speed, body kit etc.
The 2008 Portfolio was a special edition version with Alcon brakes, 525w B&W stereo & different wheels and trim.
The Portfolio term these days is used for the 'luxury' trim level package.
Old Aug 26, 2011 | 08:45 AM
dd823's Avatar
Default 2008 XKR-s Details
In Detail
submitted by Richard Owen
production 200
engine V8
position Front Longitudinal
aspiration Eaton Supercharger
valvetrain DOHC, 4 Valves per Cyl w/Variable Inlet Camshaft Timing
displacement 4196 cc / 256.1 in³
bore 86 mm / 3.39 in
stroke 90.3 mm / 3.56 in
compression 9.1:1
power 313.2 kw / 420 bhp @ 6250 rpm
specific output 100.1 bhp per litre
bhp/weight 263.32 bhp per tonne
torque 560 nm / 413.0 ft lbs @ 4000 rpm
redline 6500
body / frame Riveted and bonded Aluminium
driven wheels RWD w/Traction & Stability Control
wheel type Vortex Forged Alloy
front tires 255/35 ZR20 Pirelli PZERO
rear tires 255/35 ZR20 Pirelli PZERO
front brakes Alcon Vented Discs
f brake size x 400 mm / x 15.7 in
rear brakes Alcon Vented Discs
r brake size x 350 mm / x 13.8 in
front wheels F 50.8 x 22.9 cm / 20 x 9 in
rear wheels R 50.8 x 26.7 cm / 20 x 10.5 in
f suspension Upper Wisbone & Lateral Link w/Coil Springs, Anti-Roll Bar
r suspension Wisbones w/Coil Springs, Anti-Roll Bar
weight 1665 kg / 3671 lbs
wheelbase 2752 mm / 108.3 in
front track 1560 mm / 61.4 in
rear track 1608 mm / 63.3 in
length 4791 mm / 188.6 in
width 1892 mm / 74.5 in
height 1312 mm / 51.7 in
transmission 6-speed Automatic w/Jaguar Sequential Shift
gear ratios 4.171:1, 2.340:1, 1.521:1, 1.143:1, 0.867:1, 0.691:1, :1
final drive 3.31:1
top speed ~280.0 kph / 174 mph
0 - 60 mph ~5.1 seconds
0 - 100 mph ~11.0 seconds
Supercar Spotl
Old Aug 26, 2011 | 08:47 AM
dd823's Avatar
Default 2008 XKR Portfolio Details
engine V8
torque 559.95 nm / 413 ft lbs @ 4000 rpm
wheel type 20-Inch Polished Cremona Five-Spoke
front brakes Vented Discs w/Six-Piston Calipers
rear brakes Vented Discs w/4-Piston Calipers
wheelbase 2752 mm / in
height 1322 mm / 52.0 in
final drive 3.31:1
top speed ~249.4 kph / 155 mph
0 - 60 mph ~4.9 seconds
drag 0.341 Cd
Old Apr 5, 2012 | 05:23 PM
JustNiz's Avatar
This is not the first time that I've read the 2008 XKR-S has a slower 0-60 (5.1) than the regular/portfolio 2008 XKR (4.9).
Can anyone confirm this is actually true? If so then I'm glad I don't have an XKR-S.
To me the benefit of 175 top speed over 155 is mostly juvenile bragging rights, as its not like I'd really find an opportunity to go that fast often if ever. The extra top speed is definitely not worth any sacrifice in 0-60 time, which is far more likely to be encountered and missed in every-day driving.
You'd think at least the Jag marketing boys wouldn't allow the XKR-S to be worse than an XKR in any area of performance.
My understanding is the 2008 XKR-S is baslcally a 2008 XKR just with an uglier nose, lower/harder/smarter suspension, a slightly remapped ECU and a much noisier exhaust. Important stuff like engine, supercharger pressure, gear ratios and final drive ratio apparently remain identical.
Old Apr 6, 2012 | 07:55 AM
dd823's Avatar
I Love my 2008 XKR Portfolio and I don't need to have anymore power this car is fantastic.
Old Apr 6, 2012 | 09:49 AM
GhostriderXKR08's Avatar
Also remember the 2008 XKRS was only sold in Europe:
From Autoblog:
"Jaguar will produce a limited run of 200 XKR-S coupes, which will be offered in Europe only. Now, the regular XKR is a delectable conveyance that combines endless sex appeal with eye-widening performance. Put plainly, it is an absolute hoot to drive. The XKR-S takes all that goodness and ramps things up a bit. The 420-horsepower blown V8 is unchanged, and the XKR-S has the same 0-60 time (4.9 seconds) as its standard counterpart. What does change is the electronically governed top speed. Adding the "S" also adds 19 mph to the cat's top end, now 174 mph.
Among the myriad other changes made for the XKR-S are the addition of big Alcon Performance R brakes, a retuned suspension, and a host of visual and aerodynamics upgrades, such as new wheels with retro-logo caps, a new front splitter, side skirts, a new rear spoiler, and a rear diffuser insert. Inside, what was already a very nice cabin becomes opulent, with new interior trim, a higher-end audio system, updated instruments (to accomodate the higher top speed) and other sundry niceties. You can sum the whole thing up in two words: "fast" and "beautiful." We want."
37driver
Oct 4, 2015 05:58 PM
37driver
Oct 1, 2015 03:02 PM
millertic
Sep 30, 2015 08:11 PM
sg997tt
Canada
Sep 27, 2015 02:40 PM
