2010, 5.0 XK Convertible, Battery not charging light
Old Mar 14, 2022 | 03:41 PM
neo4star's Avatar
Default 2010, 5.0 XK Convertible, Battery not charging light
Good day Comrades,
I´ll get the "Battery not charging" light and I did some testing but with no result so far. The engine is off and the battery shows 12.6 Volts, when running in idle or with high refs I´ll get only 13 Volts on the multimeter but not higher than that.
I have changed the ground wire from the battery, with the 2 wire connector which will cut the battery if an accident happens, but it´s still the same. Any other thoughts what I should do next ? Checking fuses ? I did some but not all I guess.
Frank
Old Mar 14, 2022 | 04:49 PM
Cee Jay's Avatar
Get a new alternator. Yours is shot.
Old Mar 15, 2022 | 07:22 AM
V7Sport's Avatar
The 5.0L workshop manual has some specific testing for this problem. See the X150 stickies where you can download the manual.
Spyderturbo007
Jul 7, 2021 01:30 PM
clubking
Aug 9, 2019 04:12 AM
dawnvickieaustin
Jun 18, 2018 06:35 PM
BigHarv!
Apr 19, 2018 12:19 PM
user 36297240813
Feb 6, 2016 10:19 AM
