2010 XK Coolant leak source semi - survey
Old Nov 18, 2016 | 05:25 PM
bocatrip's Avatar
Default 2010-2015 XK Coolant leak source/overheating issue semi - survey
From the limited number of XK owners from 2010+ who have experienced coolant leak/overheating issues, how many have actually experienced which of the following as the source:?
1) Water pump
2) crossover pipe
3) Thermostat/housing
4) heater core
5) head gasket
5) miscellaneous hose
6) other
Please respond with which was responsible for your leak or overheating. I guess a survey could have been set up, but we have very very few owners of a car that was not mass produced. Any and all of your responses will be helpful for an ongoing issue. Thanks for your help guys!
Old Nov 19, 2016 | 05:51 AM
wrair's Avatar
2010 XK
1) Water pump (although also replaced 2) crossover pipe) @ 21K miles
Old Nov 19, 2016 | 04:44 PM
ralphwg's Avatar
2012 XK 40k+ miles 6, outlet or feed. I can't remember which and as I no longer own the car I don't have the service record.
Old Nov 20, 2016 | 04:06 PM
White Bear's Avatar
2011 XK 31,000 miles.
Replaced #2 crossover pipe (split along joint), also replace #1 water pump, it had lots of pulley play but was not leaking.
Regards,
