2011 XKR Overheats, radiator fans inop
Old Jun 18, 2021 | 04:37 PM
californiarobb's Avatar
Default 2011 XKR Overheats, radiator fans inop
Hey everyone,
today I noticed my AC was getting warmer, then my high heat warning light came on, I checked the coolant and all good no leaks and full, i did notice the cooling fans are not coming on, I checked fuses and all are good, does anyone know what relays control the fans or a module and where is it located, schematic anything to point me to the problem. thanks in advance
Old Jun 18, 2021 | 05:14 PM
pk4144's Avatar
Happened to me.
Bad news: the sensor that activates the fans is part of the whole fan assembly, shroud and everything-- and if it's what happened to me, you'll have to replace the whole thing.
And it ain't cheap....
Old Jun 19, 2021 | 04:39 AM
MoscowLeaper's Avatar
Good news - it's possible to fit used motor.
The motor (and the control module in it) is exactly the same with 3.0D/3.0SC XF/XJ. The shrouds and fans are diffrent, but it's easy to swap a fan to a diffrent motor and the motor will fit in XK(R) shroud, even the wire lenght is the same
Old Jun 22, 2021 | 04:17 PM
looks like dealer cost is $1150, I see they moved the fan control module directly on the fan assembly for some reason, my research suggestss the fan control modules on prior years are prone to blow caps and transistors in high heat, not sure why they decided to move it to a whole unit assy, maybe the thought was the module would stay cooler next to the blowing fans instead...
Old Jul 30, 2021 | 02:06 PM
turns out it was the fan assy, the fan control module is built in to the assy and cant take the heat, the day it went out we were having a heat wave and the outside temp was 113 F, I was sitting in my car on a long phone call when it happened, note to self.... no more long phone calls while the car is running in high outside temps above 100 F, ... Thx to all who replied.
Old Jul 30, 2021 | 02:13 PM
Canadacat's Avatar
Can you not bypass relays and let fan run anytime engine is operating?
John Baker
XJ XJ12 ( X305 )
Nov 19, 2020 12:10 PM
falderfer
E type ( XK-E )
Feb 21, 2020 09:13 AM
workoutman0011
Apr 5, 2015 08:28 PM
1995XJ609
Jan 21, 2009 01:26 PM
