2012+ OEM headlights behavior
Old Jun 18, 2021 | 05:47 PM
tmich's Avatar
Default 2012+ OEM headlights behavior
Hi,
I would be very grateful if someone record a short video of how OEM led/facelift headlights perform (2012- model). Especially:
- if led/DLR turns off with indicator
- if led/DLR turns off with HID on
- if led/DLR turns off when indicator and HID are on (changing lane at night)
If video is difficult to embed on a forum pictures would be also helpful!
Thanks!
Best regards
Tom
Old Jun 19, 2021 | 06:43 PM
ralphwg's Avatar
The DLR turns off when the turn signal on its side is activated during daylight hours. Another way of putting it is when you use the left turn signal the left DLR turns off; the right side stays on and vice versa. Not sure about it during night times.
Old Jun 20, 2021 | 05:31 AM
Barry Leftwich's Avatar
At night the DRL's are running at all times including with the turn signal.Only thing about it is you can barely see the DRL's when the head lights are on.Oh yeah,DRL's on the XK only turn on if you put the car in gear unless you turn them on manually when you 1 click over to the marker lights if you wanna see how they look while you're in park
ian_kerry
XF (X260)
21
Jun 17, 2023 01:32 PM
Candy Jones
F-Pace (X761) / C-X17
Mar 17, 2020 10:19 AM
AZjag1999
May 20, 2018 03:02 PM
QVy0790
Audio/Visual Electronics
Dec 7, 2013 09:46 PM
