2013 XKR
Old Mar 18, 2024 | 03:57 PM
ERICGGG's Avatar
Default 2013 XKR
Hi, all
2013 Jaguar XKR
69K miles
I’m going to attempt and pull the supercharger and replace all the plastic coolant hoses. Can someone please guide me in the parts needed to do this and if any other items should be looked at or replaced while this is being done. I would like to do a good service to enjoy this vehicle in the upcoming summer. Thank you all for any and all advice.
Old Mar 18, 2024 | 04:08 PM
jahummer's Avatar
I've done it a few times, have a read of this thread for some good tips regarding the pipes:
https://www.jaguarforums.com/forum/f...3/#post2729564
With that many miles done, I'd replace spark plugs, replace the PCV membranes with genuine, inspect the supercharger pulley for play and service if needed, replace the oil cooler tube between the water pump and cooler, replace belts if not recently done, inspect tensioners and pulleys.
Old Mar 18, 2024 | 04:24 PM
Cee Jay's Avatar
Since you're down that far, highly recommended to have the HP injectors replaced, or at least cleaned and tested. Losing an injector gets VERY expensive, and at 70k miles, you're right at that point.
chazaroo
Aug 8, 2021 02:43 PM
DBRNZ
Jul 8, 2021 08:32 AM
fangel
Sep 26, 2019 08:42 PM
drbbop
US Southern Midwest
May 10, 2017 09:16 AM
