5.0SC water pump
Old Sep 3, 2023 | 09:47 AM
e1rey's Avatar
Default 5.0SC water pump
My XKR 5.0 has 36200 miles on it and the water pump is leaking. Tell me if the number is correct (not original): magneti marelli 352316171311 or KRAUF KWZ1330JJ ?
Old Sep 3, 2023 | 11:11 AM
Brutal's Avatar
AJ813909 is the correct OEM, I just sold a new I had on ebay for $130. you need the updated Y pipe , bleed pipe, o ring and stub pipe water pump to oil cooler as well. You may want to just consider replacing the front outlet pipe under the SC as these rupture and you'll be halfway there. And no I do not have the part numbers for all the rest you need.
Old Sep 4, 2023 | 01:33 PM
xalty's Avatar
it’s way overdue for everything
needs the heater manifold too
Thermo
Feb 5, 2025 07:50 AM
drmike
Jun 26, 2022 07:21 AM
Michael?
Jul 23, 2021 11:07 AM
jbmi
Apr 16, 2021 07:11 PM
perezrp101
Apr 15, 2009 09:02 PM
