Adaptive Dynamics Fault
Old May 11, 2024 | 12:10 PM
jehart49's Avatar
Default Adaptive Dynamics Fault
My 2015 XK vert has the Adaptive Dynamics Fault message. I pulled the code C1B14 which is Sensor Supply Voltage A-out of range. I reviewed all the sensor data and the only ones that are out of spec are the sensor supply voltages, which are both about .5 volts low. Any suggestions besides replacing the adaptive dampening control module? If one is available new, it's pretty expensive.
Old May 11, 2024 | 03:17 PM
tmich's Avatar
Have not checked what is this code associated with, but my first reaction would be height sensor fault (at one of wheels).
Old May 11, 2024 | 03:21 PM
jehart49's Avatar
The height sensors all showed the same voltage. It was low but I'm thinking that's because the supply voltage is low.
Old May 12, 2024 | 07:18 PM
panthera999's Avatar
delete
Old May 21, 2024 | 02:40 PM
trkyam's Avatar
bad battery and or alternator, or wheel speed sensor dirty/faulty
EsRay
May 15, 2024 12:56 PM
Crash3r
Sep 20, 2021 12:23 PM
britannia
Apr 27, 2019 01:54 PM
Stumpygop
Jan 11, 2015 05:48 AM
pnfootitt
Sep 6, 2014 11:19 AM
