Rain Sensing Module fault?
Old Jun 18, 2021 | 04:05 AM
EsRay's Avatar
Default Rain Sensing Module fault?
Dear Forum,
Anyone had fun with this one, please?
Old Jun 18, 2021 | 05:55 PM
meirion1's Avatar
Can you expand on your post?
Have you got the code?
Old Jun 19, 2021 | 03:04 AM
EsRay's Avatar
Hello Meirion1, thank you for your response.
Apologies, the print on the attachment is a little small...The code is listed in the first box of the attachment...B2363
I was wondering if anyone had dealt with this DTC and if so, what steps they took?
Old Jun 19, 2021 | 05:48 PM
meirion1's Avatar
I have fiddled with mine in the past because it seemed lazy.
In your case it looks like a wiring fault is the most likely according to the code
but IMO it will be the sensor.
However first you need to measure the supply voltage to the sensor
so carefully remove sensor but before you disconnect the wire attach a piece of string to it
because if you lose the end down the hole it will be difficult to retrieve it.
If you have a voltage then I assume that the sensor is at fault.
used ones are available.
AFIK complete failure of the sensor is very rare.
Old Jan 23, 2024 | 02:42 AM
Gijzzy's Avatar
Wondering if you were able to fix it. My car has the same fault code and the automatic function is not working.
Old Jan 23, 2024 | 02:48 AM
EsRay's Avatar
Hello Gijzzy,
No, at the risk of sounding facetious, it only rains here half a dozen times a year, so I am ignoring it?
I did, however take up Meirion1's suggestion and tested for voltage (which was there), so (as he also suggested) I think the sensor has failed?
Old Jan 31, 2024 | 11:18 AM
mhamilton's Avatar
I have seen that same code in my FEM... i don't know what would have set it, since my auto sense wipers work the same as always (which is to say, wiping way more than actually needed). I have several reasons to suspect the FEMs in our cars are poorly coded, or otherwise have internal hardware failures. Time will tell if this gets worse.
Likewise, I'm ignoring it unless there's an actual failure.
My FEM also sets a code B2496 for "anti theft horn circuit short to ground" and when cleared immediately returns. Service data says this is the passive horn (the "chirp" you get when trying to lock with a door open). Well, the FEM isn't responsible for the anti theft horns, the REM is, and mine works perfectly (all horns work fine, passive and active anti theft, as well as the service horn). Searching that code shows others have experienced the same phantom error.
Old May 15, 2024 | 12:56 PM
luciod2012's Avatar
Default Help with fds2000
Hello need help with my fds2000. No red light, charges fine but no red light or cd rom read. Need to contact grizzly to purchase new adapter board. My email si luciod2012@gmail.com
sufi_786
Mar 26, 2023 10:01 AM
Big Otter
Mar 10, 2020 03:20 PM
05XK8cfe
Jun 11, 2017 08:39 AM
Davebc
May 17, 2013 07:54 AM
Drifter8282
Nov 27, 2011 04:13 PM
