Aftermarket Alloy XKR
Old Feb 3, 2024 | 07:53 AM
Jagxkr12's Avatar
Default Aftermarket Alloy XKR
Hi Guys,
I am wanting to replace my alloys on the 2012 XKR
I was wanting to see if these alloys would fit
Concerned about the fronts due to the ET range.
Also a side question, can you put an 11J on rear? I know the XkR-S came with 10.5J. I really like the deep concave look on the 11J version of these alloys.
Many thanks in advance!
Old Feb 3, 2024 | 08:54 AM
guy's Avatar
guy
To do this properly, I would start with
https://www.wheel-size.com/calc/
a tape measure and a comparison to factory spec.
Old Feb 3, 2024 | 10:32 AM
equatorial's Avatar
The short answer is yes you can use these wheels, but the measurements will have to be careful.
guy's link is helpful, and shows what the car came with from the factory, as well as a comparison tool.
The bolt pattern is 5 x 108. If the wheel chart you posted is correct, you won't be able to get 20x11 in that pattern.
I think a reasonable fit would be a 20x8.5 ET45 with 245/35ZR20 tire and 20x10 ET45 with 295/30ZR20 tire. That wouldn't exactly be factory setup, but the only risk would be 4mm slightly closer to the front fenders.
Old Feb 3, 2024 | 11:58 AM
Joe7Bros's Avatar
Center bore is a critical measurement; Center Bore / Hub Bore: 63.4 mm
TheTruth
Jul 24, 2023 02:58 PM
Andy_XKR
Sep 8, 2019 12:41 PM
gkubrak
Aug 6, 2019 11:47 AM
doowopfix
Apr 14, 2013 10:50 AM
Frog
Jan 14, 2013 09:06 PM
