Aftermarket Lower Control Arms
Old Mar 25, 2022 | 06:03 PM
JC2458's Avatar
Default Aftermarket Lower Control Arms
Hey all,
My control arm bushings are torn… I am considering replacing the entire lower control arms. Is anyone aware of any good aftermarket options in lieu of using OEM parts?
thanks!!
Old Mar 25, 2022 | 08:47 PM
guy's Avatar
guy
no. The oem solution lasted this long… would an alternative provide the same service??
Old Mar 26, 2022 | 02:38 AM
Woo5ie's Avatar
I am sure there is a post on here that lists all of the equivalent Ford part numbers that are identical to the XK parts.
I seem to remember that some of the Ford parts had a Jaguar logo on them.
Old Mar 26, 2022 | 05:20 PM
jahummer's Avatar
You didn't say front or rear but Lemforder was the original supplier to Jaguar and when purchased direct rather than through the main dealer, often as much as 50% savings. Also Eurospare is the only JLR approved aftermarket supplier and their parts offer massive savings with the same quality. Depending on use and climate, the genuine Jag replacements typically last not much longer than 5 years.
JaguarXKR
May 26, 2021 10:48 AM
prolepsis
Feb 26, 2021 06:16 AM
Razkid
Sep 2, 2017 04:34 PM
mikewv100
Feb 19, 2013 08:17 AM
