Alignment issue. Cause?
Old Apr 29, 2022 | 01:25 PM
guy's Avatar
guy
Default Alignment issue. Cause?
Greetings All,
just had my spring alignment done. What could be the cause of the misalignment on the rear right?
Taking away the obvious for you
-factory suspension arms installed and in good order.
-factory bushings installed and in good order
-rims not bent
-all tires high speed balanced.
soliciting your thoughts and experience. Thanks!
Old Apr 29, 2022 | 03:30 PM
Sean W's Avatar
if the arms and bushes are solid, I'd be looking at the hub bearing.
Old Apr 29, 2022 | 04:05 PM
guy's Avatar
guy
just checked. not the bearings.
Old Apr 29, 2022 | 05:08 PM
tmich's Avatar
I know this issue very well. Changed a rack, all of elements - no luck. Ended with an adjustable rear upper wishbones.
Pros - I have an alignment as from a factory
Cons - ride quality is rather hardcore (but I believe it will help with handling very very much), especially with my Korean antiroll bars on poli-bushes
In case an alignment wins - can help arrange a set of them (custom made in Poland).
Old Apr 29, 2022 | 05:24 PM
steve_k_xk's Avatar
If you've changed your upper and lower arms it's pretty obvious then it's going to be the stub axle .
It's the camber which is out yes ..upper , lower arms + stub axle will affect camber . Tie rod will affect the castor on the rear which is adjustable
TexasTraveler
May 21, 2021 10:38 AM
Jag69
Jul 14, 2018 10:28 PM
Porsche407
Jul 13, 2014 10:27 AM
Kay R
Jun 7, 2014 12:55 AM
BurgXK8
Apr 6, 2013 11:12 PM
