Auto tranny fluid change
#81
Here's a crazy idea, non-mechanically inclined individuals have sworn by the turkey baster method of some other fluid changes, believing after time this method will eventually have replaced all old fluid with new. For those with higher mileage or afraid of issues with a full fluid change or flush, could one simply drain, measure and replace equivalent fluid a couple of litres at a time?
The following 2 users liked this post by McJag222:
bgpenguin21 (08-30-2023),
Tracee (08-30-2023)
#83
I will ask next time I stop in there.
I almost don’t want to put this out there because I could be total wrong. I’m not skilled or experienced in this, someone more knowledgeable then I needs to confirm this. From other conversations and research my understanding is there is an access point in the bell housing that allows you to see the torque converter. The torque converter has a drain plug that can be found by having the car in neutral and slowly turning the main crank, I have no idea how that is accomplished. When you find it, it can be removed and drained. I attempted to find a picture of the access point in the bell housing, see the picture below for what I believe could be that access point.
Can someone confirm this?
RichardS (08-29-2023)
#84
#85
For the transmission, a gradual fluid replacement over time will also work fine, but the whole catch is that there is not a good way to get the new fluid in, however small a quantity. If e.g. there was a transmission dip stick leading up to the engine compartment, then draining a small measured quantity and replacing it with the same quantity via the dip stick tube would absolutely work. But for the XKR we don't have that option.
#86
#87
Oh of course, I’ve been following this thread with interest, from the start! Bit difficult to contemplate getting an accurately measured quantity in, when the car’s running and you’re trying hard to not end up a patient in your local burn unit!
Sean W (08-28-2023)
#88
You can buy an aftermarket kit for the Jaguar which fixes into the fill point and then a filler pipe leads up to a fill point which is fixed under the bonnet, much like auto transmissions used to be. You then simply drain out the sump and add the same volume of fluid through the new fill tube. It's a 15 minute job unless you want to change the filter as well but the principle is the same either way.
The disadvantage is that if you have too little fluid in there due to leaks then you will continue to have too little fluid. However, if your auto transmission underbody is always dry then I would assume that the level is correct.
Richard
Richard
Cee Jay (08-29-2023)
#89
I thought the 'fill to the brim of the filling hole' was done with the engine off and transmission cold.
#90
Richard
justinhill (08-29-2023)
#91
You need to fill to the brim of the filling hole with the engine off and then start the engine, cycle through the gears and bring the transmission up to correct temperature range. The level will then drop significantly so you then "fill to the brim of the filling hole" again.
Richard
Richard
#92
#93
Received 1,027 Likes
I do find it interesting that the drain and refill procedure in the XK workshop manual is different from the ZF transmission service manual… nonetheless, getting the fluid up to standard operating temperature in a running engine is the only way to ensure you have the right fluid level.
As for an aftermarket apparatus connected to the fill port…. not on your life.
Cheers everyone!
Cheers everyone!
#94
Seriously? I have not followed any time-based oil service intervals for the last 55 years. Some of my cars go up to 5 or 6 years between oil changes although the oil that is sitting in the sump had been in the ground for at least 60 million years before I bought it so I don't suppose that those extra 5 bothered the scorers a great deal.
Richard
Richard
#95
Richard
Richard
#96
Service intervals are a guide and you're free to service your vehicle however you like.... I service my 20+ work utes and trucks at 15,000km instead of 10,000km because it cuts my service bill from $50k a year to $30k, and my team performs daily pre-start inspections to catch most issues that would normally be spotted at a service. That doesn't mean 10,000km service intervals are rubbish, it means I've made an educated decision based on my particular use case.
McJag222 (08-29-2023)
#97
Richard
Richard
#98
Except for that one situation you mentioned above, which is the exact situation time based service intevals exist for. If you have a car that sits in the shed for ten years and only comes out once every six months, it makes complete sense to give it a quick look over once a year for things like perished hoses or seals, leaks, growing rust, or condensation that's drained into the oil. If you don't think those things are a problem for you, lucky you.
Richard
JaguarXJ8L2005
03-02-2018 10:09 AM
joycesjag
19
05-27-2010 05:39 AM
