Bank 2 misfire mystery
Old Apr 30, 2024 | 04:15 PM
wforslund3's Avatar
Default ADMIN Please delete this as double posted! Oops:(
I have an 07 XKR. I developed a progressively worsening p0300 and p0316 and codes for misfires on 2, 4, 6, and occasionally 8 over a 3 day period. I limped home the last 1/4 mile at sbout 5mph at idle. I had replaced all plugs about 3 months and 2k miles prior so I was in there with all the brittle plastics etc. I did gap plugs and torqued. Battery is new and holds 12.8 at rest. I've switched coils from one side to the other. I changed oil and verified VVT volts and ohms. I checked electrical specs on O2 sensors and upstream was a bit suspect so I replaced all 4 (just cuz). I had received a p0430 5000 miles or more back and it would rarely show and I could clear it with Torque Pro. It did go away after plugs...??? I've hooked up JLR SDD v136 and get wildly fluctuating fuel trims on bank 2. I pulled air filter and it was 'normal' dirty and replaced. While there cleaned MAF sensor. I know that it's gotta be ignition, air or fuel. Absolutely no codes from Bank 1. While I was doing O2 sensors I did the bang test on the cats and the drivers sound more dull thud then drivers. O2 sensors now read pretty good, consistent voltages, but I can't really get (or dare) to run long enough to be sure alls cool. I am suspecting CAT or a vacuum leak on some bank2 specific vac line. Anybody got any advice?
Thanks so much in advance.
Bil
Old Apr 30, 2024 | 04:24 PM
guy's Avatar
guy
Original CATS? How many miles on the car?
Swap the mafs side to side?
The workshop manual provides good insight on the magic of fuel/air ratios and all of the components measured by the ecu in calculating the approach. All I'm saying is don't rule out clogged cats.
wforslund3
May 4, 2024 12:31 PM
mittzlepick
Mar 19, 2024 07:27 AM
mayhem
Sep 8, 2022 02:20 PM
Norcat
UK & Eire
May 10, 2022 11:18 AM
Wight8
Jul 25, 2020 05:35 AM
