battery charger hook up
Old Dec 3, 2017 | 09:33 AM
defalco733's Avatar
Default battery charger hook up
can you use the terminals in the trunk to hook up a trickle charger over the winter months on a XKR?
Old Dec 3, 2017 | 10:45 AM
jagtoes's Avatar
If you mean the positive + post in the left side of the boot behind the plastic grill the answer is yes. Also see the owners manual for proper hook up.
Old Dec 3, 2017 | 11:27 AM
Stuart S's Avatar
Welcome to the Forum. You'll find lots of useful information and helpful owners here. Learn to use the Search function, as almost every question has already been asked and answered.
Below is a link to the definitive thread about smartcharger installation. Note that there is a significant difference between 4.2L and 5.0L charging systems. For 4.2L models, It's OK to use either the remote battery terminals in the trunk or attach the + and - smartcharger leads directly to the corresponding battery terminals. For 5.0L models the - smartcharger lead must be connected to a chsssis ground.
Since you have a 2009 XKR, see my posts ## 161 and 224 on psges 9 and 12, respectively, in this thread. I preferred to use the remote battery terminals in the trunk, instead of connecting directly to the battery.
https://www.jaguarforums.com/forum/x...lation-107738/
Old Dec 3, 2017 | 03:43 PM
defalco733's Avatar
Thank you...I read the threads and understand. I used a Battery Tender 12V, 1.25 amp for my 1996 XJS Conv. (sold it) and that worked fine. Will that be ok on the 2009 XKR Conv. 4.2L?
Old Dec 3, 2017 | 05:14 PM
Stuart S's Avatar
My last Deltran Battery Tender was made in China and had a plastic case. It overheated and melted the plastic case. Fortunately, it didn't cause my house to burn down. Worst customer service ever. I'll never buy another Battery Tender brand product again.
I use a BatteryMIINDER Plus on my 2009 XKR (4.2SC)and a CTEK MUS4.3 on my 2013 XJ (5.0SC). They both work well, but I prefer the CTEK because it is a newer design from a highly regarded company. I recommend replacing the Battery Tender with a CTEK MUS4.3.
Your car, your life, your money, your choice.
Old Dec 3, 2017 | 09:57 PM
ralphwg's Avatar
+1 on the Ctek. Also you can do the whole Ctek bit for less than $100 including an extension cord. Look on EBay or Amazon.
Old Dec 4, 2017 | 12:04 AM
kj07xk's Avatar
Been using a ‘Battery Tender Plus’ for three years with no issue, the case is all metal, and barely gets warm. Extensions are available (use a 25 foot one normally, and have a second 25 footer that I can use to extend to a car in the driveway if necessary).
Bigg Will
May 30, 2017 08:36 PM
twack
Dec 5, 2016 10:51 AM
domino_z
Nov 18, 2016 05:01 AM
Xx_Xtype_xX
Nov 9, 2016 10:02 PM
sjuraud
Aug 28, 2010 02:11 PM
